spare tire replacement
Old Feb 28, 2012 | 06:38 PM
brucksch's Avatar
brucksch
Default spare tire replacement
My 81's spare tire is dried out and cracked. Where can I find a replacement?
Old Feb 29, 2012 | 11:11 PM
mark79,80's Avatar
mark79,80
I did the same search a few years ago and could not find the original
80 series spares available. I found that a 205 75 15 tire will mount
on the original spare wheel and fit in the spare tire compartment
without having to lengthen the latching bolt.
This size is also very close in height to the original size tires on the
car, that is 255 60 15.
Old Feb 29, 2012 | 11:37 PM
Drawmain's Avatar
Drawmain
I just did this two weeks ago on my 82. Get the 205 75 15, it mounts on the spare rim just fine and fits in the carrier without issue.
Old Feb 29, 2012 | 11:45 PM
Ironcross's Avatar
Ironcross
My original spare was finally removed from its tub,....Out of air, its a F-70 15......
Old Mar 1, 2012 | 12:46 AM
Clubby99's Avatar
Clubby99
Spare tires that fit 15x8 rims are available almost everywhere. Also in all the sizes mentioned in this thread except the F series (you would not want that tire).
Old Mar 1, 2012 | 01:20 AM
Ironcross's Avatar
Ironcross
probably not, but its the OE spare size for those that are numbers and everything else correct....A never on the ground spare tire.........{NOS}......
BTW, the rim size for a 1968 is 15X7 and 15X8 for all the rest
Old Mar 1, 2012 | 02:13 AM
Clubby99's Avatar
Clubby99
No kidding but the OP is a 81
Old Mar 1, 2012 | 06:45 AM
rdroe's Avatar
rdroe
DC Area Events Coordinator
Here's another approach. I went to the local salvage yard here and picked up a Corvette mag, bolt pattern the same, for about $28. Great tire and fits just fine. I wanted a little more than just the spare. I took it home, cleaned it up and it's perfect. I took the original SPARE tire & rim to my local MR Tire first. THey says that they were not allowed to replace the tire on the rim that was marked SPARE TIRE USE ONLY. Not sure I believed them, but I am happy with my spare and how I will never use it anyway! It's there for looks & Safety.
Old Mar 1, 2012 | 09:26 AM
Hadez's Avatar
Hadez
You can get a newer Caddy or GTO as a spare if you want to retain the skinny tire size and have it fit up in the carrier.
Old Mar 1, 2012 | 11:19 AM
qwank's Avatar
qwank
Doesn't an '81 have a space saver donut?
Old Mar 1, 2012 | 11:28 AM
rdroe's Avatar
rdroe
Not that I know of. A *spare-rated* tire to be sure, but full size.
Old Mar 1, 2012 | 11:45 AM
qwank's Avatar
qwank
i'll have to look at mine. I always thought it was a donut. haha
Old Mar 2, 2012 | 11:40 AM
HeavyMetalHawk's Avatar
HeavyMetalHawk
I had the same problem with my original spare tire, so change for the 235/60 R15 that are the same of my car right now and no problem fit in it in the tube.
Old Mar 2, 2012 | 12:10 PM
joewill's Avatar
joewill
also consider if you do not have a equal height spare tire that is the same height as your other tires and you put it on your rear, you will quickly eat up your posi clutch packs.
Old Mar 23, 2012 | 03:21 PM
brucksch's Avatar
brucksch
This is exactly my concern. I have been on Tirerack looking at the details on the specs to match revolutions per mile with my current tires.
Old Mar 23, 2012 | 03:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yes.
To spare tire replacement
