Door Panels
Old Mar 3, 2012 | 08:18 PM
68vetteman's Avatar
68vetteman
Default Door Panels
I'm getting ready to install new door panels and at the top of the panel it looks like there will be a gap that will show the steel part of the door. Is there a piece of trim that goes on the top of the door panel? The PO had a bead of black silicone and the outer rubber door seal to fill the gap. If anyone has a picture it would help me a lot. Thanks
68 Vetteman
Old Mar 3, 2012 | 08:46 PM
PA14JIM's Avatar
PA14JIM
My door panels have a window wipe with chrome bead attached to the extrusion that hooks over the opening on the door. It is attached with staples to the door panel.
Old Mar 3, 2012 | 09:56 PM
2001convertable's Avatar
2001convertable
same here. There is a chrome strip with felt to bridge the gap and meet the window.yes its stapled to the door panel
Old Mar 3, 2012 | 11:18 PM
DZRick's Avatar
DZRick
Based on your user name I'm guessing you have a '68.
There is a piece that bolts to the door on the '68 that has the whiskers riveted to one side and a rubber filler to the other.
I'll see if I can find the recent post where Willcox had a link to the parts you seem to be missing.
Old Mar 3, 2012 | 11:27 PM
DZRick's Avatar
DZRick
Go to the 15th post in the following thread.
http://forums.corvetteforum.com/c3-g...8-or-69-a.html
Old Mar 3, 2012 | 11:59 PM
68vetteman's Avatar
68vetteman
Thanks guys I didn't know there was a rubber seal that goes on the inside. I only bought new felts and the outer seals for the door panels. While I had everything apart I also put power door locks on.
68 Vetteman
Old Mar 4, 2012 | 11:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 68vetteman
...I didn't know there was a rubber seal that goes on the inside...
68s used whiskers and they could be hard to find. AIM shows them. Order the AIM.
If memory serves, 68 door panels do not have a rubber window wipe on the panel. 69 and later cars do.
Old Mar 4, 2012 | 04:07 PM
loup68's Avatar
loup68
Army
I use the later 69 outer seal on my 68. The rubber makes more sense than wiskers to seal out water. You have to use the 68 only inner seal, howerer.
To Door Panels
