Is a '77 a normal car?
Old Mar 4, 2012 | 09:34 AM
anesthes's Avatar
anesthes
Default Is a '77 a normal car?
I don't know anything about C3's other than inspect the frame and hope the birdcage isn't rotted...
I'm looking at a '77 Corvette today.. Previously I owned an '87, and between the digital dash, strange electronics, etc it was just a bizare car to restore. Almost NOTHING was shared in between car lines, accessory brackets, water pump, power steering pump nothing. When a gauge stopped working it was a $500+ fix. I know the '90+ got even worse with the body control module.
How are the '77's in this regard? Is this something that has basic components, normal radio slot, and not electronic/computer controlled everything?
I'm assuming a '77 TH350 car will be a 3.55 ratio posi rear end. Are these basically the same dana44 gear sets as the C4?
Anyone have a picture of the underside of one of these cars? I'm curious if it has a crossmember for the transmission, or a silly cbeam like my C4 had. I have a 412" sbc and 5 speed trans w/ lakewood bell housing, I'd like to stick in the car.
Which leads to the next question - are repop Pedal and z-bar kits available and cheap, or ultra-expensive like the hydraulics on the C4? On my '79 Z28, I got a pedal and zbar kit for under $200 including springs and rubber boots.
Thanks guys!
-- Joe
Old Mar 4, 2012 | 11:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by anesthes
...I don't know anything about C3's...
Good reading here:
...How are the '77's in this regard?...
Kinder and gentler.
...normal radio slot...
77s share the regular GM stereo line up. Early cars did not and have Corvette specific two part radios.
...electronic/computer controlled everything?...
No computers on 77s.
...I'm assuming a '77 TH350 car will be a 3.55 ratio posi rear end...
Posi was standard, but the base ratio was probably 3.08:1 If the 3.55 was available with the TH350, it would have been optional.
...are these basically the same dana44 gear sets as the C4?...
No. Eaton rears are under the 77s.
...Anyone have a picture of the underside of one of these cars?...
Try Google > Images. You will probably kick up dozens of underside views of C3s.
...I'm curious if it has a crossmember for the transmission...
Yes.
...are repop Pedal and z-bar kits available and cheap...
Yes. But why look at a factory automatic if you want a four speed. Buy a 4 speed car.
Good luck with the hunt.
Old Mar 4, 2012 | 11:39 AM
Mark Riles's Avatar
Mark Riles
Good answers above. Just my small addition to the thread is that automatic cars have a removable cross member and the manual cars have a welded in cross member. It'll be up to you which is easier. Modifying the cross member in a car set up for manual, or adding a pedal assembly to an automatic car.
Old Mar 4, 2012 | 12:01 PM
anesthes's Avatar
anesthes
I imagine there is a differnt crossmember for the 700R4 cars (1982?)? The setup I have would require either moving the TH350 crossmember back 3inches or so, or finding whatever GM used to make a 700R4 fit. (same length). This is also assuming the 700R4 used in a C3 was around 31" long.
I think it would be easier to swap pedals and linkage in a auto car, although I'd also have to source a console I suppose.
Thanks for the replies guys!
-- Joe
Old Mar 6, 2012 | 07:53 PM
iokepakai's Avatar
iokepakai
Did an auto to manual trans swap last year.Pedals were a challenge but very doable. Auto trans crossmember is removable but will have to be modified for your 5 speed.The clutch linkage is another obstacle that will need to be tackled.If you have a TKO trans you may try a 700r4 Bowtie trans crossmember. My 76 Vette is so much more fun to cruz around with the manual trans!! Here's my write up:http://forums.corvetteforum.com/c3-t...am-change.html
Good luck...
To Is a '77 a normal car?
