What to do, help prioritizing projects and money.
What I have: 1976 L48, 43000 miles, only things NOT original are:
Brakes and calipers redone 3 years ago.
Both half shafts redone last fall with new spider bearings, rear bearings lubed.
Manifold back exhaust redone 3 years ago.
Rear end new gear oil/posi additive last fall.
New battery and alternator 5 yrs ago.
Tranny serviced 2 summers ago.
Plans in the near future (in order):
1. New spider bearings on driveshaft. (spiders on hand)
2. New valve covergaskets, oil pan gaskets, replace front and real main seals. ($55 fel-pro gasket set from NAPA)
3. Flush coolant and block, replace any bad coolant lines, new thermostat.
4. Engine tune up with recurved distributor (once I figure that out), rebuild carb? with kit from Cliff?
5. Inexpensive headers and true dual with x-crossover thingy.
6. Would like to put a little free-er intake on when doing gasket work if there is one recommended without cutting hole in hood.
7. New weatherstripping set - need towel to drive when raining - Wilcox seems to have best price at $235.
8. Replace suspension bushings, shocks, rear 9-leaf spring.
9. Redo parking brake (currently removed at rear hubs).
Phew....did I mention a decent stereo and speakers?
So, here's my question, assuming a budget of $1000 initially (not including stereo
) What would you experienced folks suggest and where would you get the parts?Do I have the order correct?
More importantly, what did I forget that is more important to do than anything else?
Thanks for your help. Just so you know, I am military and have access to a do-it yourself shop on base. There is very little work that I can't do myself with some old crusty mechanics around to help me through the task.
John
Dirty jobs are no problem...I also have a 94 Land Cruiser that I do my own work on, so muddy, old grease knows how to get under my fingernails
I know that other things will pop up, typically when I am ready for a big cruise!, but I am ok with that as well. Thats where the AAA upgraded membership comes in.
Thanks!
Its a big job that could keep the car down for awhile for something unnecessary.
The dash sux for putting in an after market stereo.
If the cars running good, go for the dual exhaust so it at least sounds fast!
After some minor stuff - brakes is next!!!!
Hoses and gaskets are a good idea too. That should help as the pass side cover usually leaks onto the manifold. Mine did.
The weatherstripping will keep you and the interior dry if you get caught in the rain.
Add up some prices after that and see what you have left. Just those mentioned above should help you get a more dependable vette..
(2-4 basically at the same time.)
1. New spider bearings on driveshaft. (prev used wrong term - just new bearings in u-joints))
(just trying to free up airflow for 20-30 more horsepower - just for fun so will save for "as money available" project)
Thanks for your recommendations. Is there a common problem that needs preventative maintenance that I am missing?
It's taken 5 years to do all these repairs and upgrades.I do a lot of research before I decide to do any mods and before I purchase the parts.I have been burned by some really junk parts and learned the hard way all parts are not created equal. This forum has been a valuable asset to get this Vette running like it should.Get your projects done one at a time with safety first then the fun stuff after.
Good Luck with your projects and research,research before you spend your hard earned dollars.....Aloha's
[IMG]
[/IMG][IMG]
[/IMG]
Figures...I have a brother who lives on the Atlantic in Charleston SC, my car has a brother who lives in Hawaii...
And we both live in Ohio........
Anyway, I think I have a plan.
Will get the SR carb rebuild kit from Cliff's, get a felpro engine gasket kit from NAPA and get new plugs, wire, rotor, etc and replace the top end engine seals while the carb is off. Once rebuilt, redo the ignition system, set up the recurve and timing, then adjust the carb per Lars's tech papers.
Any opinions on the NAPA felpro gasket kit? It would be the generic SBC one.
Kudos to Cliff and Lars, Cliff emailed me personnaly about rebuilding the carb and so did Lars with some tech papers, even though I understand he had surgery recently.
These communities are a band of brothers, and are an example of the true America.
Anyway, I digress...time to spend some money.
Thanks!
I got mine from Summit, around $60 all in
FEL-1885 Oil pan gasket
FEL-2702- front and rear seals, timing cover, water pump gaskets, etc
Good Luck!
