Dash Harness Electrical Questions
Old Mar 6, 2012 | 05:27 PM
andycw's Avatar
andycw
Default Dash Harness Electrical Questions
Hello All,
I removed the Dash harness from the 72 yesterday and am in the process of checking all the connections. However I have located a couple surprises and was hoping someone may be able to id what they are. the first is pictured below. Does the "Key Buzzer" supposed to look like this?
It appears to be some sort of cap on it.
Second, the stop lamp switch seems to have some sort of resistor wired into it and I don't see this on the doc rebuild wiring diagram. It has definitely been wired in at some point but what for? Should I remove it and just rewire the connections?
Old Mar 6, 2012 | 05:32 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
second pic is a capacitor, installed to stop the pop noise when you put on the brakes thru the stereo, the componet/capacitor is probalbe toast from age. remove it.
Old Mar 6, 2012 | 05:34 PM
Sully1882's Avatar
Sully1882
Andy,
I'll look tonight and confirm but on my 72 I'm pretty sure mine look just the same. The door buzzer is correct. I'm not 100% sure on the resistor but it looks like I remember that just like yours is.
Sully
Old Mar 6, 2012 | 05:43 PM
andycw's Avatar
andycw
Default thanks
Thanks Folks. That was quick! Ill remove it now.
Old Mar 6, 2012 | 07:37 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Yes, the first pic is the buzzer, and the second pic is a capacitor, and I have the exact same thing on my car.
Old Mar 6, 2012 | 10:53 PM
andycw's Avatar
andycw
Default more questions
Alright, here's more. I looked at the doc's rebuild wiring diagram there are a couple of items that seem odd. First, is this what the power connection for the cig lighter looks like on your 72?
Secondly, where does the light immediately to the right of the cig lighter connection on the diagram fit? On my 69, if I recall correctly, it fit in the ashtray somewhere?
On the 69, the lighter connection looked like this:
Is this the correct lighter for a 72? what is the spade on the side of the lighter for (at about 1 oclock)
Finally, what fits in these holes?
Old Mar 7, 2012 | 10:27 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Not sure about the holes but the spade on the cig lighter accepts a ground wire to complete the circuit for the lighter element.
I don't remember that my element had a post connector; I remember a spade connector. I'll see if I can confirm that and report back.
Old Mar 7, 2012 | 12:20 PM
Mashman's Avatar
Mashman
On my 72 the terminal on the lighter is connected to a orange (always on) power connector. The ground for the lighter is thru the shifter plate. So, I think that your lighter is not original.
The lighter should have a metal shroud with a bulb in it. It clips onto the side of the lighter, and is illuminated with the rest of the dash lights.
There are two other bulbs that connect to the underside of the shift plate. There is a bulb that connects under the Heater/AC controls (I believe this is a unique bulb), and the other (at least for my automatic) bulb connects to the hole in your picture, it illuminates the shift positions ('PRN123').
Also, I believe the hole in the bottom picture is just to be able to access the screw underneath - no bulb goes into it.
Roco71's Avatar
Roco71
In the third photo the hole is for a light socket that should light up the shift selector
Old Mar 7, 2012 | 12:25 PM
Roco71's Avatar
Roco71
The center of the lighter is hot the same (circuit) orange wire that connects the clock.
To Dash Harness Electrical Questions
