trim damage - putty?
Old Mar 7, 2012 | 03:44 PM
brianPA's Avatar
brianPA
Default trim damage - putty?
There's damage to the foam trim on my drivers side birdcage/windshield. I was hoping to just replace the piece but from what I've read here removing this trim requires windshield removal, which I'm not prepared to do. Instead I'm thinking of getting some kind of putty and molding it by hand, gluing, dying, and texturing to match (with a reverse imprint of the same area's surface). Any suggestions?
Old Mar 7, 2012 | 04:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Trim screws and velcro are the only things holding it. AIM shows how it was installed. Remove the trim screws at the header and possibly one in the pillar post trim. With the screws out, gently tug on it and the velcro will release.
You do not have to fiddle with the windshield.
Old Mar 7, 2012 | 04:07 PM
Mark Riles's Avatar
Mark Riles
Easy to remove and easy to replace. Where on earth did you read that the windshield had to some out?
Old Mar 7, 2012 | 04:15 PM
Mooser's Avatar
Mooser
It was the chrome piece on the top (with the insert to catch the bullet from the t-top) that needed the glass removed. The pillar covers are not so bad at all.
If you still wanting to try a repair, there is a product line called shoe-goo and they make automotive goo and marine goo and a few others. It's like a really thick silicone type product.
I fixed a foam shifter **** on a winter-beater VW Fox I had with the stuff once and it actually worked pretty good all-things-being-equal
Mooser
Old Mar 7, 2012 | 04:19 PM
brianPA's Avatar
brianPA
I read some other threads that mentioned this, maybe they were talking about different trim pieces. Great to hear, gonna order a brand new one! Thanks
Old Mar 7, 2012 | 11:30 PM
20mercury's Avatar
20mercury
Default goo or goop?
Mooser
I am thinking this is goop not goo??? If goop, like marine goop, automotive goop, plumbers goop, agree that is good stuff, nice all purpose glue, seals great and you can get it off if need be. I have used it on all kinds of stuff.
Old Mar 7, 2012 | 11:33 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Might want to order an AIM while you're at it.
Old Mar 8, 2012 | 06:56 AM
Mooser's Avatar
Mooser
Go figure, I just googled it and the company calls it shoe-goo but "everything else"-goop. That is the stuff. Made by a company called eclectic.
Old Mar 8, 2012 | 10:26 AM
20mercury's Avatar
20mercury
Default Well maybe you right!
Wow! For shoes, it is goo, but for everything else it is goop?? Anything made by a company called eclectic must be good! I am thinking hippy mad scientists must have invented it!!
Old Mar 8, 2012 | 01:50 PM
Mooser's Avatar
Mooser
If you get a good wiff of the stuff I think you'll experience the same inventive process that they do.
You know how they make something environmentally friendly and it doesn't work as good anymore? that hasn't happened with these guys.
Mooser
Old Jun 28, 2012 | 03:23 PM
brianPA's Avatar
brianPA
Okay so I finally got around to doing this.
Ordered a new front left pillar, medium saddle. I think it was around $50, forget.
Fit was perfect. Color is little off but I'm pretty sure mine is just slightly yellowed and dirty from 38 years of time and likely people smoking inside. The grain is nearly perfect, too.
One thing that was really annoying is that the main attachment screw hole... wasn't a hole. I had to drill one out through the metal backing, it wasn't just the vinyl cover. There was a mark where the hole should have been. Poor manufacturing? Intentional? I dunno. Otherwise it installed fine.
Old Jun 28, 2012 | 04:02 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by brianPA
...There was a mark where the hole should have been. Poor manufacturing?...
No.
...Intentional?...
Yes. The manufacturer made allowance for you comparing their part to your original and determining where you needed the hole for your car. The same piece on my car could have the necessary hole in a slightly different place. Same part, two different cars.
Old Jun 28, 2012 | 04:16 PM
cb.bums's Avatar
cb.bums
i was disappointed with the fit looking in from w/s. if you ever have just a corner one these type pieces that are cracked and the foam shows through, trim up the edges and apply 3M plastic emblem cement to it. be liberal. let dry for a full day. you can sand it to regain your contour and spray it with vinyl dye. i saved my door panels with this.
Old Jun 28, 2012 | 05:58 PM
brianPA's Avatar
brianPA
Looking through the windshield the fit looks pretty good to me. Not quite as tight as the other side but I never would have noticed unless you mentioned it.
Of course, as soon as I ordered the left pillar I noticed that the right side is starting to fray slightly. I'll try your fix.
Old Jun 28, 2012 | 11:13 PM
7T1vette's Avatar
7T1vette
If you don't like the color difference, take the one you removed to an auto body paint supply store and have them mix up a 1/2 pint of SEM ColorCoat vinyl dye ($15). Also, pick up a PreVal bottle/gas canister sprayer ($10). You can clean the surface of the new part and shoot two light, covering coats of dye and install it 30 minutes later. And, you will still have most of that can of dye left for other parts/repairs that you will need down the road.
Old Jun 29, 2012 | 11:49 AM
brianPA's Avatar
brianPA
Hah I was just gonna rub some sludge on it and then wipe off to keep a little in the cracks for that nice "40 years of Marlboros" look to match the rest of the interior.
To trim damage - putty?
