Drivers visor keeps dropping..
Old Mar 11, 2012 | 03:36 AM
alconk's Avatar
alconk
Default Drivers visor keeps dropping..
How can you tighten up the visors so they don't drop down while driving? Driver's side is bad.
Old Mar 11, 2012 | 08:16 AM
Double_0_7's Avatar
Double_0_7
Mid-America sells a visor refresher kit. Don't remember exactly what it's called, but it's only around $20, as long as yours has all the stuff but is just a little tired.
Edit: it's on page 89 of the catalogue I have. I bought the $24.99 suvisor elbow repair kit, but you should check some of the other listings as one of those might be closer to your needs.
Old Mar 11, 2012 | 08:28 AM
demoke's Avatar
demoke
Mine did the same in my 80...I went simply old school and removed the visor(remove pin) and put some electrical tape on the post(small amount so visor can stol slide over) and reinstalled and it has worked fine. Worked for me. All it cost me was a little time. Good luck.
Old Mar 11, 2012 | 09:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by demoke
...I went simply old school...
Old School? I call that using your head.
Old Mar 11, 2012 | 02:17 PM
alconk's Avatar
alconk
I like that idea and gonna try that. Thanks!
Old Mar 11, 2012 | 03:49 PM
Phil Zell's Avatar
Phil Zell
Just remove and use a little rubber mallet persuasion, gently
Old Mar 11, 2012 | 04:44 PM
aussiejohn's Avatar
aussiejohn
Default Little blue pill??????
They say this works for bits that have a tendency to droop.
Can't speak from personal experience though.
Regards from Down Under.
aussiejohn
Old Mar 11, 2012 | 08:19 PM
qwank's Avatar
qwank
if its just drooping, all you need are these bushings:
http://www.ecklerscorvette.com/corve...1979-1982.html
just be carefull taking the visor off. I hit mine too hard and broke the arm, so I had to order the whole repair kit.
To Drivers visor keeps dropping..
