Was the right hand mirror an option on the 75 Stingrays? Mine does not have one and I was thinking of having one installed when I have the car re-painted....good idea or no?
Thanks, guess I will be looking to add that when it is time for paint. I would much rather just glance at the RH mirror than have to turn around and look over my shoulder.
My 75 doesn't have the passenger mirror either... I was thinking about that too... I'm still a bit undecided. But it sure seems like adding the mirror would be safer.
Since you will probably be removing the LH mirror to get the car painted, make a template of the mounting holes.
Trace the edge of the door line (fender edge) and the top edge (window edge) and mark the holes.
Flip it over, align the edges, and mark your holes on the right door.
I recently installed a RH mirror for a friend on his 76. Although the new RH mirror comes with a template, it did not look like it was correct.
Turns out the L door had been replaced after an accident and the mirror re-installed as a "close-guess". I wanted to install the RH so it would look correct, even though the spacing was not factory, and not "off" to the eye.
BTW: The LH mirror mount has factory threaded mounting holes in the door. The RH mirror will mount a little different since there are no threaded mounting holes there....
I put a RH mirror on my 68 for increased visibility. Better safe than sorry! As Paul mentioned, it comes with a template and was the easiest thing I've done by far to a car.
I think C3s look alot meaner with the single, left-hand mirror. My '69 has one (not my choice), but the '75 does not. I always do the full head turn, no mirror necessary.
Thanks for the tips, I must say, I have been a forum member for one day and I am VERY impressed with the quick responses and good advice, you guys actually care.
So is there any type of metal backing attached to the fiberglass in that area? Modern mirrors are spring loaded or break away. Thought about adding a passenger mirror to my 75 but was always afraid someone would whack it and end up destroying the door. Those mirrors are sturdy and stick out pretty far.
Never had my driver's door apart to see if there was any type of steel support behind the mirror.
I've had an extra pair of mirrors for the last 2 C3's and just can't bring myself to drill into the door . . .one of these days . . . . .
drilling is the hardest part. I have a full set of chrome louvers ready to go, I think I've fitted them up 30 times. I'm certain my marks are correct. But I'll drill and it will all of a sudden become clear that it is in the wrong spot.
No, there is really nothing behind the door where you want to mount the mirror, whats why the kit has those well nuts that expand. I didn't think too much of the mounting system.
That is the reason i went with a metal plate glassed in, yes its a pain to use a dremel and clean out the area behind it, and fit a plate in there.
I installed a RH mirror about 3 years ago for safety sake.
I used the well nuts that was recommended and they worked for about 1 year....then they began to loosen. No matter how many times I took the mirror off and re-tightened the base, it would tighten temporarily and then it would began to shake when I was going down the road.
I really wanted to have a RH mirror but the only REAL way to install it, is to attach a steel plate inside the door (just like the LH mirror) then it will stay tight. But to do that, I understand, would be a real pain.
When I get the Vert painted, I'm going to have the body shop install the RH mirror with the plate.
I finally took off the RH mirror, had the 2 holes in the door filled and the door repainted. Now you can't tell there was ever a mirror there.
