2 bolts hold the lock post bracket on. Gotta take that bracket off anyway to remove the top cover over the spare to access the gas tank.
Take it off with the lock in place, spray the lock up with WD40 or such.
Door key SHOULD fit the spare tire lock.
The lock is held in place by a spring-loaded rod opposite the hole in the side of the assembly see... http://i130.photobucket.com/albums/p...nane/lock2.jpg
You want to push a wire or something through the hole, around the bolt for the spare wheel and push on that rod while pulling the assembly down and off. I made my little tool from a piece of stainless off a wiper blade. See... http://i130.photobucket.com/albums/p...nane/lock1.jpg
This last photo is a poor picture of the tool pressing on the pin. http://i130.photobucket.com/albums/p...nane/lock3.jpg
It's easier to work from the right side of the hole when the lock is installed.
Hope this helps,
Joe
It's not for my '75 it's for my '69 I have just started
Can't drive it it's a long way off from that
I will try to open lock as you guys described or I will
Take the bolts out
Hope this helps,
Joe
Followed these instructions/photos, and it worked like a charm! Thanks, thirteen-year-old post!
