Door Panel Snag
Old Mar 22, 2012 | 10:56 PM
68vetteman's Avatar
68vetteman
Default Door Panel Snag
My door repairs are coming along. The window regulators are fixed. I found inner seals for a 68. The door release and power locks are installed. Now the door panels. I got the basic door panels from Corvette America and the look is great but the fit leaves something to be desired. I'm trying to get the clips to lock and hold but they keep popping apart. It has been driving me crazy thinking I did something wrong. If I take a clip from the original panels and push it on the door it pops and locks strong. If I take the same clip and put it on the Corvette America panels they push on and pull off giving no holding power. So in conclusion the door panels are held on by 4 screws. The clips are useless and the panels don't fit close to the door. Just like the originals I took off. Is this a common problem? The panels look good but it is a shame they don't use good quality clips so the fit matches the look. Sorry for the long rant I've been working toooo long on the doors.
68 Vetteman
Old Mar 22, 2012 | 11:39 PM
7T1vette's Avatar
7T1vette
I'm not sure the locking plastic 'peg' pieces are compatible with the original units. You might have to drill off the old ones from your original panels and the new ones from the new panels....then pop-rivet the old ones on the new panels, so they will stick. Also, if there is a 'bow' in the new panels, you may want to set the panels out in the sun [back side out...good side down] and let them heat/soften a bit before you install them on the door.
Old Mar 23, 2012 | 07:20 AM
Phil Zell's Avatar
Phil Zell
When I did my old 68 I bought the same panels as you did, after finding out that they were less than desirable, I returned them and bought Al Knock. The AK panels fit like a glove
Old Mar 23, 2012 | 11:46 AM
loup68's Avatar
loup68
Army
You should not have to change the "velcro-snaps" on the car! Send them back. I know I am disgusted with the way almost all reproduction parts available now, do not fit right or do not look right, after redoing my 68 last summer.
Old Mar 23, 2012 | 06:37 PM
68vetteman's Avatar
68vetteman
I already put holes in 1 panel for my trim pcs.
Old Mar 23, 2012 | 06:55 PM
7T1vette's Avatar
7T1vette
I had similar problems when I ordered inside windshield pillar trim pieces. There were Corvette America pieces (purchased from another vendor) and the plastic clip pieces didn't even make contact with the ones on the pillar. The inner metal sub-frame was dead-straight; the OEM part has a natural curve. When I called C.A. about the problem, they weren't even aware that the part wasn't configured the same as the OEM parts...."Been selling them for years." was their response. Apparently, folks bought them, had problems with them, but didn't complain.
In the end, they didn't plan on making any changes to their processes. They said I could return the new parts, but then I wouldn't have any other source for a decent (appearing) replacement part. So, I did what most of us would do....modified it so that it would work. Nuf said....
Old Mar 23, 2012 | 09:10 PM
loup68's Avatar
loup68
Army
68vetteman, I would still return them after calling them, and telling them about your problem They sell door panels with the side trim installed, tell them that. They can still reuse them. 7T1vette, I had the same problem with my 68 pillar covers. Worse than that, the driver side hardly covers up the pillar when you look from the outside in. It looks like crap. I can so kick myself for tossing my originals when I moved here from Ohio. I could have had them recovered. Doesn't Mid America make their own pillar covers? Does anyone know?
Old Mar 23, 2012 | 09:49 PM
Lupigiato's Avatar
Lupigiato
I didn't see this thread when I responded to the video of the door panel Velcro issue. In my reply I mentioned my experience with the windshield pillars and then I saw this post where Loup68 had the same issue I had. Kind of comforting it wasn't me, but for the premium$ we pay for repro's wouldn't you expect a premium quality product?!
Old Mar 23, 2012 | 10:35 PM
7T1vette's Avatar
7T1vette
Hey, they're the only 'act' in town and WE are the 'captive audience'.... They are not particularly customer-oriented nor concerned that much with Quality. So, we get whatever they are willing to sell us--until we finally decide to holler "ENOUGH"!!!
To Door Panel Snag
