Rear Spring
I would like to ask the difference of the spring rating between the rear spring fitted to a 1973 454 big block and that of a 1980 gymkhana spring.
The rear spring on my 73 has lost its tension in three of the leafs , and i have a new spring from a 1980 , will this affect the handling of the vette in a detrimental way at all and can it be retrofitted ???
John
Andrew
800-442-0335
http://www.muskegonbrake.com
Thanks a stack for your input on this one .
i am going to see if the local guys can rebuild it to original , only because of the weight problem and the shipping costs .
If it cant be restored then i think i will have to go the same route as i went with my 80 vette , and fit a carbon fibre unit .
Thanks for the reply this forum and the guys on it are just brilliant
John
