Tdc ?
Old Mar 24, 2012 | 05:51 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Default Tdc ?
TDC on Compression stroke for # 1 cylinder is "dot" on CAM Gear at 11:00-12:00 position, and "dot" CRANK Gear at 6:00 position.
When "dot's" are above each other CAM at 6:00 and crank at 12:00 then # 6 cylinder is at TDC COMPRESSION stroke. CORRECT?????
Old Mar 24, 2012 | 06:55 PM
BKbroiler's Avatar
BKbroiler
Dave - You should install the cam when the crank sprocket's dot is at 12 o'clock. Set the cam sprocket dot at 6 o'clock. Then install your lifters, pushrods and rockers and adjust your lash with the intake manifold off so you can see when each lifter is on the base circle. Rotate the crank with a wrench, with the sparkplugs out. When the lash is set, look for both #1 lifters on the base circle and then your timing marks should be close to zero. Put the manifold, etc back on, drop in the distrib and advance it a few degrees. That should be close.
Old Mar 24, 2012 | 09:25 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Thanks!
Old Mar 24, 2012 | 09:51 PM
noonie's Avatar
noonie
No, crank at 12
Originally Posted by noonie
To install the new set, forget about TDC and align the dots (with pushrods removed or rockers loose) to meet at 12 and 6 oclock as palmbeachvette76 pictured and 63mako described. This position is not #1 TDC on the firing stroke.
To get the #1 firing stroke after gear set installation, continue to rotate the crankshaft another full turn so the dots are both at 12 o'clock and install the dist so the rotor meets #1 on the cap. No need to check the piston position for TDC when you can see the gears.
Old Mar 25, 2012 | 10:12 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
No, crank at 12
You caught my mistake, THANKS. And Thanks again for the advice
Old Mar 25, 2012 | 12:53 PM
Skip Burney's Avatar
Skip Burney
Cam gear dot at 6 and crank gear dot at 12 and make sure they are exactly opposite each other and not a tooth off either way
Old Mar 25, 2012 | 06:30 PM
Ironcross's Avatar
Ironcross
except your firing on #6 not #1....which is not all that bad as you can set the rotor at #6 plug in the cap and fire right up
Old Mar 25, 2012 | 10:34 PM
Skip Burney
If the cam and crank gears are set right and 1 is at TDC it dosen`t matter where you put the rotor as long as it is wired correctly. You just have to be sure the vacum advance has room to swing for timing adjustment and the tach cable isn`t pinched.
To Tdc ?
