81 Bumper Removal
Old Mar 29, 2012 | 11:39 AM
73737373's Avatar
73737373
Default 81 Bumper Removal
What's the best way to remove the front bumper? I have to repair the fiberglass reinforcement that's behind the urethane covering.
Old Mar 29, 2012 | 12:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have the assembly instruction manual (AIM)? The AIM shows how the bumper cover was installed (essentially it's bolt on); remove it and you have access to all the actual crash bumper hardware.
Old Mar 29, 2012 | 12:10 PM
73737373's Avatar
73737373
No, do not have the AIM, but have removed a front bumper from a 1977. Assuming its largely the same process for an 81; unhook the parking lights and the bumper cover is held on to the body by a series of nuts/bolts around the perimeter.
Old Mar 29, 2012 | 12:23 PM
Easy Mike's Avatar
Easy Mike
Yes. Order the AIM; they're handy.
Old Mar 29, 2012 | 12:25 PM
commander_47's Avatar
commander_47
It's really not that hard, but definitely a couple of PITA moments.
There are 20 or so 10mm nuts that hold the bumper on. Most of these are accessible with a 1/4 inch drive ratchet with an extension. If the bumper is stock, then you'll figure out real quick that these are not real nuts holding them on, but rather those stamped steel nuts that bend easily if reasonable care is not taken.
You will have to remove the valance to get up there, and the four nuts in the center between the lights are a bit of a pain. In fact, it is much easier if you remove the lights altogether.
I have seen where some people simply take a dremel tool and run it along the seam between the bumper and fiberglass thereby cutting the bolts.
Above the marker lights there are 4 or five more nuts. BEWARE, the one right on the corner where the bumper turns is actually a stud. So is the one at the end by the wheel. These studs break off very easily as the stamped nut tends to be rusted here.
Old Mar 29, 2012 | 03:49 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by commander_47
...I have seen where some people simply take a dremel tool and run it along the seam between the bumper and fiberglass thereby cutting the bolts...
Obviously, when they got out the Dremel tool, they did not realize the studs they were cutting were part of the retainers.
Old Mar 29, 2012 | 06:12 PM
commander_47
Exactly
Only costs 24.00 for a new set.
I am confused about the "fiberglass bracing". All of the retainers go through the fiberglass lip and are bolted. There isn' t even a gasket. The honeycomb is simply some sort of plastic that is bolted on.
Uploaded with ImageShack.us
Old Mar 29, 2012 | 08:01 PM
Mark G's Avatar
Mark G
You should be able to figure it out. Jack up and support with jackstands so you get your arm up (waaaay up) in there with a 1/4" ratchet and socket. You'll need some extensions and maybe a swivel. A few retainers on the side but these are all pretty obvious. Give it a try..
To 81 Bumper Removal
