New Keys Not Working
Old Apr 2, 2012 | 10:05 AM
75_Stinger's Avatar
75_Stinger
Default New Keys Not Working
I had a new set of key cut, the door key works fine, the ignition key does not. Has anyone ever sanded down new keys to add some ware to them. I am guessing because the new keys have sharp edges my older ignition does not like that.
Old Apr 2, 2012 | 10:24 AM
oldalaskaman's Avatar
oldalaskaman
if you still have your old keys, take them back to the key shop and have them do them right....this time
Old Apr 2, 2012 | 10:43 AM
7T1vette's Avatar
7T1vette
An old key usually has the tip worn down from use. If the guy/gal who made the new key didn't take that into consideration (place the old key in its holder with some offset for that wear), the new key's notches will be in the wrong place. Put them on top of each other and line up the 'stops' with each other [the squared-off protrusion just below the head of the key]. Then compare the notches. If they are in the right places and are approximately the right depth, you might want to run a wire wheel (powered, if you have it) over those new notches to "blend" the edges a bit. If not, take the key back and have it re-done correctly.
Old Apr 2, 2012 | 11:34 AM
75_Stinger's Avatar
75_Stinger
Thanks, I am thinking I can just work the new ones a little to match them a tad more to the old ones. I went to Lowes to have them cut, I called two locksmiths in my area and they don't copy keys so I really didn't know what else to do.
Old Apr 2, 2012 | 11:55 AM
oldalaskaman
in that case, sit in your car while you do it, file a bit, try it, file a bit more, try it, takes a little time but may keep you from filing to much, keys are pretty soft.
Old Apr 2, 2012 | 05:49 PM
den(thevetteman)78's Avatar
den(thevetteman)78
Just go back to the place where they cut your keys and have another one cut correctly. It's not that hard.
Doest it have the same letter on your new key? Each model years had a different letter stamp on the keys. I know in '78 the door keys have the letter K and the ignition keys it's a J.
To New Keys Not Working
