Door Panel Question
Old Apr 2, 2012 | 11:37 AM
75_Stinger's Avatar
75_Stinger
Default Door Panel Question
I was wondering if the arm pads that are on my door panels were an option or something the PO stuck on. My deluxe door panels are in good shape and I am planning on replacing the wood panels and carpet but I have not seen these before:
Thanks!
Old Apr 2, 2012 | 11:55 AM
MakoShark72's Avatar
MakoShark72
Aftermarket! Quick, cheap stick-on repair. High wear area and probably cracked underneath!
Old Apr 2, 2012 | 12:10 PM
75_Stinger's Avatar
75_Stinger
Cool thanks, I guess I will carefully pull them up to see what is underneath.
Old Apr 2, 2012 | 12:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 75_Stinger
...I will carefully pull them up to see what is underneath...
Leave well enough alone.
I had a pair of the patch panels in my '74.
Old Apr 2, 2012 | 01:48 PM
MakoShark72
You probably won't like what you find....
Old Apr 2, 2012 | 02:57 PM
7T1vette's Avatar
7T1vette
You may do more damage by pulling them up. If they will clean up OK, I agree with the "leave them alone" strategy.
Old Apr 2, 2012 | 03:03 PM
75_Stinger's Avatar
75_Stinger
I ran out at lunch and took a peek, it looks like they are held on with 3M tape. The ends are starting to seperate so I wanted to know if these were replaceable. I think I will still pull them up and if what is underneath is bad, I will try to tighten up the ends and put them back on.
Old Apr 2, 2012 | 03:10 PM
73Corvette's Avatar
73Corvette
Yes you can replace them......I would probably use a hair dryer or heat gun to "warm" them up good before and while gently lifting them off.....
be sure a peek under as your doing it to make sure your not making things worse......
Old Apr 2, 2012 | 04:44 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
or park the car in the sun with the windows closed for a bit and heat up the insides. that will also make it a bit easier to remove them. i would go lightly on the heat gun method, if you choose to use something. i would use the hair blower before a heat gun.
Old Apr 3, 2012 | 01:48 AM
77BLACKNSMOKE's Avatar
77BLACKNSMOKE
New set cost under $35
Old Apr 3, 2012 | 07:01 AM
Mooser's Avatar
Mooser
On a real hot day mine started to slide somewhat.
Hard to say with your but just to throw it out there, I put mine on to protect the new door panels (probably not required but...) so underneath (and yes I've had them off a few times, hair-dryer works) it's not cracked.
So did your get put on to cover a problem (probably) or put on to prevent a problem (probably not) and the winner is ?????????
Oh, yeah it's just a double sided foam tape
Mooser
To Door Panel Question
