Doesn't make sense to me........
Old Apr 3, 2012 | 08:43 AM
73Corvette's Avatar
73Corvette
Default Doesn't make sense to me........
I've spent a lot of time and effort as many of you trying to rid our car of the issue of heat in the cab.....have put most of the resources I have on the interior of the car to stop it.....and I got to thinking...why, IF it's already made it's way into the cabin.....it's tooooo late! Yeah I can keep the floor boards from turning into frying pans.....but I need to STOP this heat before it gets to the cabin......Will direct more effort to rejecting/redirecting/ or reflecting HEAT before it even has a chance to warm up the cabin...........geez I am sooooo slow.
Possibly some kind of aluminum shield, sorta like a skid plate the will fit in front of the firewall and tranny tunnel to divert heat down and out.......they have some tiny little plates right in front of the foot wells......good thought just not enough.
Old Apr 3, 2012 | 08:51 AM
imariver's Avatar
imariver
I always thought the same thing, stop it before it gets into the cab. I mean lets face it, you wouldn't put insulation on the inside of your house ..................
Old Apr 3, 2012 | 11:08 AM
BKbroiler's Avatar
BKbroiler
The driving force of heat transfer is temperature difference. The greater the temp. difference between two areas, like under the hood / interior of the car, the more heat will flow from the hotter area to the cooler. Lets say its 75 deg in the car and 175 deg under the hood. The temp. difference is 100 deg. But if its 75 deg in the car and 195 under the hood the difference is 120 degrees, or 20% more. That will cause 20% more heat to flow into the interior. What I'm driving at is lowering your engine temp will lower your interior temp. (Heat from the exhaust under the car is another issue.) If your engine runs a little hot, try improving that situation.
Old Apr 3, 2012 | 12:59 PM
jim-81's Avatar
jim-81
I think that's part of it. But heat transfer from one object (or area) to another is impeded by the amount of insulation. The better (or more) insulation, the slower the rate of heat transfer. Anything you can do to improve the barrier, or reduce the rate of heat transfer helps. Heat shields will prevent RADIANT heat transfer (think a light bulb or the sun), insulatiing mat, like Dynamat will help with heat conduction. Use as many barriers as you can.
Yikes! I haven't had my car yet in the summer
Jim
Old Apr 3, 2012 | 01:08 PM
PRNDL's Avatar
PRNDL
Before you even start worrying about heat transfer through fiberglas and metal make sure there are no air leaks from the engine area into the passenger compartment.
Old Apr 3, 2012 | 01:11 PM
U17's Avatar
U17
Two words... headers and sidepipes
Old Apr 3, 2012 | 01:14 PM
AdamMeh's Avatar
AdamMeh
Jim
Same here - Phoenix temps and this car should prove interesting.
Old Apr 3, 2012 | 01:18 PM
woodsman,ab's Avatar
woodsman,ab
I agree with trying to stop the heat source from underneath the car,but I do think a reflective barrier will help, as long as you glue it down to the surface so there is no airspace between the two to heat up and disperse throughout the car. Your keeping the heat on your floorboards longer,therefore allowing the flowing outside air to whisk it away before it works its way into the cab.(to a degree).Same thing with a house. If you dont insulate properly and end up with dead airspace in your walls due to lack of insulation, the heat and cold will transfer right through to your inside wall. The way I look at it,your floorboards are the plywood sheeting on your house.The reflective insulated barrier is your insulation,and carpet is the drywall. Just my own silly theory.
Old Apr 3, 2012 | 01:32 PM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
Solution ...
Drive around with the heat on and windows up every day \ all day.
Get the cab to about 160 \ 170 , this will cause a reverse osmosis type of thingy so the heat from the cab will leach into the engine bay ...
See how easy that was .
You're welcome
Just kiddin by the way , I've yet to drive my 73 in any heat so to speak ... This could get interesting .
Old Apr 3, 2012 | 02:24 PM
sfallison's Avatar
sfallison
I have seen some interesting things to do..
Try Lizardskin on the outside tranny tunnel and under body Saw it done on an episode of Trucks!). You can also wrap your exhaust to keep heat from radiating out.
A good insulator on the inside is good too, but stopping it from the outside is better!
Old Apr 3, 2012 | 08:41 PM
imariver's Avatar
imariver
Originally Posted by Redwing01
Solution ...
You're welcome
Will this ger rid of my love handles??
Old Apr 3, 2012 | 09:20 PM
73Corvette's Avatar
73Corvette
[QUOTE=Redwing01;1580457168]Solution ...
You're welcome
Your such a dork! I may try that when the wife isn't with me.....
Old Apr 3, 2012 | 09:21 PM
73Corvette's Avatar
73Corvette
One word.... original. well two crap...........
Would love to do that but, can't....
Old Apr 3, 2012 | 09:37 PM
RU7376vettes's Avatar
RU7376vettes
There are supposed to be heat shields on the front of the firewall and also a reflective heat shield on the bottom side of the tunnel above the transmission. There is also supposed to be a foam collar between the bell housing and the tunnel to block the air from going in this area.
I also added reflective insulation on the floor boards under the carpet. 73's didn't have a shut off valve to cut the water from flowing through the heater core. You can add a manual valve to solve this problem.
You should also check to see if the seal and the cold air intake flap on the hood are working properly, if not you will get heat coming in through the kick panels.
I can now drive my 73 without cooking my feet to well done.
Unk
Old Apr 3, 2012 | 09:48 PM
73Corvette's Avatar
73Corvette
OK...here is what I have done so far....
Completely smothered the floor with Dynamat...
Put in new air dam....
Stuffed as large a foam collar, piece 4'x4'x18' of memory foam between bell housing and tranny tunnel...
Tranny tunnel blanket...
Header wrap......
Put in B-cool aluminum radiator (stays right on 180)
Blocked off and sealed vent door behind kickpanel on passenger side...
Cut off valve in heater line
The only thing I haven't done yet is re-seal all the grommets in the firewall and the joints where A/C housing connects to firewall.....
It is WAY better than it was....but, I am going to beat the heat if it's the last stinkin thing I do to her dang blasted car...hehe
Old Apr 3, 2012 | 09:59 PM
den(thevetteman)78's Avatar
den(thevetteman)78
To solve this problem i instaled a cutoff valve similar to this at the intake hose that leads to the heater core. Work real good i even installed headers and it's cooler than when i had the factory manifold. Now i can enjoy my car in the warm sunny days.
Old Apr 3, 2012 | 10:08 PM
oldgto's Avatar
oldgto
Y`all are starting to scare me! Our 71 is a NON AC car, and we live in Florida! Did I just buy a giant microwave oven with wheels on it?
The car originally came from North Carolina, and we plan to retire there with it.....
IF we don`t bake to a crisp here first!
Old Apr 3, 2012 | 10:55 PM
73Corvette's Avatar
73Corvette
Already did that.....
Old Apr 3, 2012 | 11:45 PM
noonie's Avatar
noonie
Your concept is very sound.
When you get a chance, take a look at the doghouse of a van.
They are made of relatively thin fiberglass/plastic surrounding part of the engine and exhaust, but very little heat gets transferred into the cabin.
You will be surprised at what little material it takes.
To Doesn't make sense to me........
