Need help with 73 decal/label clarification
The second pic are repops from the aftermarket suppliers.
My question is, why are they so different.
Does any other 73 owner have these similar labels, my build was Oct 20/72, if that matters.
Now, if I use the repros, will they look correct for a 73.
Please, if anyone has anything similar or the same, chime in with an explanation, thanks.
All things considered, your original labels look pretty good. I would reapply the original labels.
Carefully, smooth out the original tags and reapply them to the car in the same locations. As far as "how" to reapply them, I would use the following approach:Clean the surface of the part well; position the tag where you want it; make pencil marks at egdes of tags; remove tag, then make a 'border' at those marks with blue painters tape; use a spray can of contact cement to shoot a light layer or two onto the part; also apply the contact cement to the backside of the tag; allow to tack up (per can instructions); remove masking and tape; place tag in position and rub it down with a clean cloth.
I've used this approach with good success and not had tags come loose later.
Now I know the location of the Fridgedaire label, but can't remember the exact location for the Harrison, anyone got any pics to show where ????
My 73 (housed in another state at the moment) was built in Oct 6 1972. Here are two pics taken during a recent radiator replacement. The L82 is original along with the compressor (upgraded to R134) and the condensor (?) box. The decals are original and still in good shape but are barely visible. Hope it helps. Fran
Based on past experience, my first thought would be that the repro you have is correct. At the same time, I think the the "CODE NO." on the label you removed, was a date code. 0918721 may be 09-18-72, 1st shift, which would fit nicely with a car built on Oct. 20, 1972!
The Harrison evaporator label from your car, has me a little confused also. Most evaporator labels I have seen, have the model year in the lower left box (the "73" in the number EBA-70-73B on your repro), as part of that part number. As such, my first inclination is that the repro Harrison label is correct, but unlike a compressor, the evaporator box and the label on it, aren't as likely to get replaced on a car.
An old friend of mine in Oklahoma, use to know a lot about 73's. He restored, what we believe to be the first 73, to ever receive a Bloomington Gold. His health hasn't been good lately, and I don't know if I can reach him, but I will try to call him in the next day or 2.
I know I haven't helped you much, and may even have confused you further. I know your labels have me pretty confused.
