Brake light reset
Old Apr 5, 2012 | 01:34 PM
VetteNURSE's Avatar
VetteNURSE
Default Brake light reset
Can anyone tell me how to reset the brake light on my 76 if stopmping on the pedal doesn't work?
Old Apr 5, 2012 | 01:44 PM
Greatsteaks's Avatar
Greatsteaks
Reset? Do you mean get them to turn off? There is a switch located at the brake peddle might be stuck.
Old Apr 5, 2012 | 02:13 PM
VetteNURSE's Avatar
VetteNURSE
Sorry i mean the brake warning light on the dash, triggered by the eaqualizer block.
Old Apr 5, 2012 | 02:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The pressure differential switch is supposed to center itself if you tromp the brake pedal. If that does not work, the switch is stuck or you still have a brake system problem.
Old Apr 5, 2012 | 02:39 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Press harder
Old Apr 5, 2012 | 02:55 PM
VetteNURSE's Avatar
VetteNURSE
It came on after a hard stop, brakes feel and seem to work fine. And I'm pressing pretty hard.
Old Apr 5, 2012 | 03:33 PM
Easy Mike's Avatar
Easy Mike
Go to a safe area (empty parking lot) and try another hard stop. It might reset.
Old Apr 5, 2012 | 03:58 PM
Mike Ward's Avatar
Mike Ward
Fix what caused it come on then.
To Brake light reset
