battery hold down bolt
Old Apr 16, 2012 | 11:52 PM
StingrayLust's Avatar
StingrayLust
Default battery hold down bolt
So I'm curious as to those who are using the "correct" 1-1/4" bolt with pinch point and captured washer for their battery?
I actually ordered the "correct" part but it seems a bit short when I try and put it in. Yes my battery is not a period correct battery, it's a teeny, tiny bit too wide it would seem as the bracket sits too far back and the bolt won't grab. Is this an earthshattering problem, no, the replacement bolt I bought for 70 cents works just fine. I just wanted to know if I was the only one not getting mine to work.
Some pictures:
Old Apr 17, 2012 | 12:45 AM
scottyp99's Avatar
scottyp99
My 'vette had no hold down bolt when I bought it, and when I saw how much they wanted for a new one, plus shipping, I did what you ended up doing: Went down to Home Depot and bought a bolt. Been happy about it ever since.
Keep the shiny side up!
Scott
Old Apr 17, 2012 | 09:34 AM
jcloving's Avatar
jcloving
I use my original. I cleaned it and the hold down bracket. I did have to put a small shim under the battery but it works like a charm.
The PO just had the batt loose back there!
Old Apr 17, 2012 | 10:08 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Curios what the diameter and thread are on that bolt? The captured nut on mine is so corroded that I cant get a thread chaser to start.
Looks kind of like a 3.8 X 16
Old Apr 17, 2012 | 10:32 AM
flyeri's Avatar
flyeri
Looking at the picture i count what looks like 9 threds in 1/2 inch. I had mine out last week. I have the stock bolt but I had to make another hold down bracket.
Old Apr 18, 2012 | 04:55 AM
hunt4cleanair's Avatar
hunt4cleanair
I picked one up at Carlisle a couple of years ago for a couple of bucks and its the correct length (1-1/4"). Got it for the Pace Car that the PO, like others had the battery rolling around in the back.
Old Apr 18, 2012 | 06:34 AM
indydoug's Avatar
indydoug
Not me. My battery was also loose, I found the hold down clamp in the debris around the battery, but not the screw. I actually used the screw from the EGR valve (which was not functional, so I replaced it with a block-off plate using shorter screws.) It has the correct threads, but it is 1-1/2" long with a smaller diameter captive washer and full threads (no tapered point). It looks about the same as your replacement bolt. I don't see how a larger diameter washer, or fewer threads would have worked.
Old Jul 4, 2012 | 02:31 PM
Paleden's Avatar
Paleden
Default Hold down Bolt
I have an original and it is difficult to thread even under the best of circumstances.
Old Jul 4, 2012 | 06:02 PM
my 76 ray's Avatar
my 76 ray
Don't feel bad. My '74 has a bolt and a nut on the underside. I just can't reach the bolt and nut at the same time.
Old Jul 4, 2012 | 06:10 PM
Roco71's Avatar
Roco71
I bought the correct bolt last month as well and yes it was to short.
Old Jul 4, 2012 | 11:50 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
My battery just sits in the compartment. I found the brace the other day, but I just put it in the compartment and left everything as is.
To battery hold down bolt
