*** 1968 Vette Question ***
Old Apr 18, 2012 | 07:28 PM
bkvette3's Avatar
bkvette3
Default *** 1968 Vette Question ***
Good evening, guys (and gals)
Does anyone know the GM part # for a starter brace bracket. 427 with a TH400 tranny??? No luck finding it in the A.I.M. Thanks in advance. BK3
Old Apr 18, 2012 | 08:32 PM
loup68's Avatar
loup68
Army
Blair, My 1953-1974 parts book says: 66-67 corvette (427) (except H.D. 4-speed) and 68-69 corvette (427) brace is number 3864972 . But it also lists 67-69 corvete (427) (exc. H/per., H.D. 4-spd.) brace 3932398 . May be someone more familiar can sort this out for you, Lou.
Old Apr 18, 2012 | 11:11 PM
bkvette3's Avatar
bkvette3
Thank-you, loup68. That helps me out immensely. Appreciate your time BK3
Old Apr 20, 2012 | 10:55 PM
bkvette3's Avatar
bkvette3
Would anybody be able to post a pic of this brace installed on the starter of a big block with a TH400. Just curious what this looks like installed. Thanks in advance. BK3
Old Apr 21, 2012 | 10:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Looks to me like installation is the same as regular production. UPC 6 Sheet B 2. UPC L 36 Sheet A 5 shows the same brace, but a different heat shield for the big blocks.
Type of transmission appears to make no difference. M40 section does not show anything different.
Old Apr 21, 2012 | 11:01 AM
bkvette3's Avatar
bkvette3
Type of transmission appear to make no difference. M40 section does not show anything different.
Good morning, Mike. Thanks for pointing that out to me. I went thru the AIM countless times and missed both pages. Still some what confused. Looks like 2 different style braces. Here's what I have:
OR is this one correct:
Is one for big block/small block or auto/manual trans??? Thanks again for your help. Much appreciated.
Old Apr 22, 2012 | 09:55 AM
69 Chevy's Avatar
69 Chevy
I find it hard to believe that the multitude of '68 owners on this forum have yet to come to your aid, bkvette3.
But mention that the '68 model year Vette was the biggest piece of crap to come off a GM production line during the 60's decade and responses defending their darling would go on for pages. Go figure?
Old Apr 22, 2012 | 10:18 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by 69 Chevy
...I find it hard to believe that the multitude of '68 owners on this forum have yet to come to your aid, bkvette3...
I'm a 68 owner. I came to his aid.
...But mention that the '68 model year Vette was the biggest piece of crap to come off a GM production like during the 60's decade and responses defending their darling would go on for pages...
You have a right to your opinions concerning the 68s, or any other model year for that matter, but your response to BK offered no help at all.
BK. The lower, longer one looks correct to me. The first one appears to be a GM service part replacement.
Old Apr 22, 2012 | 03:03 PM
BBCorv70's Avatar
BBCorv70
I looked up Group 2.042 3965588 in the Part List and Illustration Catalog, Corvette, 1953 - 1982. It comes up as a starter brace for 70-74 454.
For 68 you have a few choices, some #s may be service part #s...
The brace for..
67-69 427 W/H.D. (EXC. T.H.) comes up as 3866768.
67-69 (427)(EXC H/PER,H.D. 4-SPD) 3965589
68-69 (EXC. 427 T.H.) 354353
68-69 (427) 3864972
Old Apr 22, 2012 | 06:54 PM
bkvette3's Avatar
bkvette3
The brace for..
68-69 (427) 3864972
Thanks Roger for the info. The search goes on for the correct brace.
Regards, BK3
Old Apr 22, 2012 | 07:20 PM
loup68's Avatar
loup68
Army
Blair, The above post shows that 3965588 is wrong ( 70-74 454). 3866768 is wrong for a T.H. The above post is incorrect about 3965589. My 53-74 parts book lists it as for 70-72 350 (exc. HD 4-spd) , 73-74 350 , not for a 427. The newer number 354353 is wrong for a 427 T.H. That leaves you with the two numbers that I gave you in post # 2. I do not know why there are two different braces. I am sorry, I have a 327, now 350. Paragon corvette is only showing one BB brace # 1441 and they make it. I would use your part # 3932398. Lou.
Old Apr 22, 2012 | 07:59 PM
BBCorv70's Avatar
BBCorv70
Blair, The above post shows that 3965588 is wrong ( 70-74 454). 3866768 is wrong for a T.H. The above post is incorrect about 3966589. My 53-74 parts book lists it as for 70-72 350 (exc. HD 4-spd) , 73-74 350 , not for a 427. The newer number 354353 is wrong for a 427 T.H. That leaves you with the two numbers that I gave you in post # 2. I do not know why there are two different braces. I am sorry, I have a 327, now 350. Paragon corvette is only showing one BB brace # 1441 and they make it. I would use your part # 3932398. Lou.
The posting came directly from the GM parts book, 53 - 82 Corvette. If the listings are wrong, Chevrolet is wrong. The parts manager for a Chevrolet dealer gave me this book. It's possible numbers changed over the years, could be service part numbers. I could try to post a photocopy of this page if necessary.
BTW: Part numbers changed over the years, service parts. My manual is a 1982 edition, part numbers may have changed from the 1974 edition mentioned by another. If you're interested in absolute originality, your best bet is an AIM. A year or two after production, who knows what substitutions were made for service?
If it doesn't show in the AIM, best you can do is go by the part numbers showing in the parts manuals. It's possible the 1974 edition may be closer to original though the 1982 edition is certainly not wrong so far as functional parts are concerned, probably service parts.
Old Apr 23, 2012 | 08:30 AM
69 Chevy's Avatar
69 Chevy
As you do many, many times. Not only about the quirky '68 models but C3's in general.
I said what I said as a means to bring this thread up to the top of the forum because I thought it deserved more exposure. I could have just as well typed BTT. But I decided to spur more responses by using invective. And that still didn't lure more '68 owners out of the woodwork with well reasoned answers to the OP's starter bracket question.
My only help is posting this page from my '73 edition of the P&A 30b; he can pick which one he thinks is correct:
Old Apr 23, 2012 | 08:47 AM
bkvette3's Avatar
bkvette3
Thank - you Appreciate your help. BK3
Old Apr 23, 2012 | 09:22 AM
69 Chevy's Avatar
69 Chevy
You are welcome. Copy it now as I will be deleting it shortly.
Old Apr 23, 2012 | 10:07 AM
bkvette3's Avatar
bkvette3
Done. Where does one pick up one of these GM parts books that everyone refers to??? E-bay??? Thanks
Old Apr 23, 2012 | 10:34 AM
69 Chevy's Avatar
69 Chevy
I have no idea where folks get them nowadays.
I got all mine from a very cooperative Chevy parts manager who was to throw them out when the new ones arrived but gave them to me instead. I did all the part number scrounging for my parts orders...he gave me wholesale discount in return.
To *** 1968 Vette Question ***
Old Apr 23, 2012 | 12:25 PM
loup68's Avatar
loup68
Army
BBcorv70, I did not mean to offend anyone. I only want to keep the record straight for someone reading this in the future. I assumed chevy goofed in printing the 53-82 copy. The parts books are hugh and to get everything correct has to be a rough job. I would go cross-eyed! I just realized that I have a 53-78 parts book and it shows the 283,327,350 brace #3186511 was changed to #354353. It also shows #3965589 for 70-78 350. I still think that the #3932398 is correct. I bought my parts books over the chevy parts counter. When they went to computers, you could not buy one anymore.
Old Apr 23, 2012 | 12:58 PM
BBCorv70's Avatar
BBCorv70
No problem.
I didn't think I was hallucinating, these books can be tough to read with the footnotes regarding applications. Rather confusing. Over time GM substitutes parts for replacement. If the OP really wants an authentic original part, best bet is to check out an AIM for the original part number. Second option may be to ask a current 68 owner to take a photo of the original part for comparison.
Old Apr 23, 2012 | 01:06 PM
BBCorv70's Avatar
BBCorv70
The parts manager for a Chevy dealership gave me one for free back in 1983... I'm not sure anyone reprints them now..
Here's a link to one on eBay...
http://www.ebay.com/itm/1953-1982-NE...09409864351191
Many part numbers may have been substituted over the years. You may be better off with an AIM if you want original part numbers. This manual may be of help if you need part numbers for components not shown on the AIM such as internal motor parts, etc.
