HERES MY PROBLEMS:
How available are these windsheilds? Mines got a crack and needs to come out anyway, shouldn't be too hard right??
- Headlights are a big problem, what causes the bottom of the headlight bezels to hit the support underneath?? They go down about a few inches then stop. somthing is obviously way out of wack. I plan on fixing the actuators and replacing all the rubber lines, but this is a bigger fish that needs to be fried. Is there an adjustment that needs to be made or any suggestions how to fix this?
Thanks so much !
Windshields are readily available and cheap. I bought a PPG windshield from a local glass shop to install myself, it was less than $150 about two years ago.
Just make sure that the installer (or you) have the glass set at the right "depth" in the windshield frame, a gap will result between the glass and the stainless trim if it's set too close to the frame, conversely if it sits too far out the glass may be so close to the stainless that installing it may be a problem.
Here's my tip... slow down and concentrate on a single task at a time. Reassembly is the exact reverse of disassembly so start your renovation with the last component you removed from the car. Do that, and only that step until it is absolutely complete. Then do the next, and so on. If you approach this project from six different angles at once you'll end up even more frazzled than you are now and will likely quit in frustration before anything gets completed. It also helps enormously to see real progress as jobs get checked off the list, and your funding will be focused since you'll only be purchasing parts to complete one task at a time.
Markids77 is right on. Everything can get so overwhelming you end up throwing in the towel or start to hate what you love, the vette. Take one step at the time with the first step as Easy Mike suggested. The books are worth more than any mod or repair you would ever want to make.
"Ignorance is bliss.".....until you find out that it's not.
Not knowing enough about what you are doing [or what you need to do] can cause you to get into a lot of trouble with a C3 (or any old vehcile). Get the documentation you need to understand what it takes to work on your car. Then, read and understand them. THEN, get to work on the car.
At this point, you need to "take a break", buy the AIM (Assembly Instruction Manual...which was used as reference material by the Corvette factory), study over the components you need to be working on, make a plan for how you will do the work, then 'dig in'.
Going at things blindly...or in the wrong direction...can cause you to reap more collateral damage than actual benefit from your work!
THanks Champs about the windshield, that seems easy enough!
Could anyone tell me why the headlight bezels hit and stop on the support underneath? This is my main problem... and would like to approach it while everything is open and all the junk out of the way.
Adjust your attitude... you asked for help and are discounting the advice of people here who have completed cars already and have taken the time to offer advice. The Assembly Instruction Manual (AIM) contains step by step directions, part number references and excellent "exploded" line drawings, and was used by the factory as a guide for putting your car together at the factory. The GM chassis service manual contains detailed instructions and OK photos of how to remove, rebuild and reinstall/adjust everything on your car to include the headlights; and the vacuum system which makes them work. These books are not "optional" if you would rather work on the systems of your car than ask questions here and sit around until you get the info needed. They're available used on Amazon and eBay and might be the best investment you can make for your car.
Some photos of the interference might help. There's a tutorial on posting images on the site if you're new to this. You describe both "bezels hitting" and "sagging headlights"; these seem to be seperate and perhaps unconnected problems? Will the lights function properly if you remove the bezel and operate them "naked"?
Do you know how to eat an elephant? One bite at a time.
These gentlemen have given you excellent advise....deep breath.....one more.....exhale......there you go. HAVE FUN and enjoy the process.
Yes exactly, with the bezels removed they have plenty of room to clear...
Bump - photo updated... you can see where the headlight bezel is hitting the support underneath. Where would i go about making the adjustment to fix this?
Thanks so much.
YellowC3: I'm guessing your headlight doors need to be centered in the openings.
Thanks Easy Mike, That sounds reasonable, I just ordered the '76 AIM so hopefully i'll be able to figure out how to approach the adjustment... as well as everything else on the car. Thanks to everyone for helping and the informative posts.
