My 75 Vette Thread
This is my dad's 75 Vette. We are currently in the process of installing a new carpet set into the car, along with re-assembling the dash and drivers' door. Below, last weekend before we left for a local show :
That is my dad working with it there. He is also on here, WA4DBY. Today's work environment
This is one of the jobs that we will be doing today when we get back from church.
Carpet that is going in
Another interior shot
Seats
Something else we are doing today is to refurbish this panel
Lastly, the motor (complete with period correct valve covers)
There will another update today, hopefully with the rear of our interior completed.
Anyway, this is them as of now
On to the rear carpet, we started fitting it but got tired and did not want to mess anything up. So, I'll try to get him out there tomorrow.
That's all for now.
What we glued it in with
Tomorrow, we'll be going at the other side, and hopefully finishing it off with the middle piece.
I don't see any in the pics but, maybe its just the angle of the pics or there aren't any on that model?
I'm just guessing from the pics that may be the source of some of the issues in the "truck" of the car, the water from the plenum drains straight inside and runs down soaking the carpet and the hinges on the doors until it finally settles and drains out the storage compartment....
You will see the same kinds of issues in the future if these are not replaced.........
It shows them as available from Zip for a 75,, so I will assume yours need replaced......
this is a picture from the outside......behind the tire in the fender well.....this is where the water from the Grilles behind the back glass is supposed to drain
NOT inside the car.
This is the repair solution I had.....didn't want to rivet it.. ALL Stainless Steel I used a small grinding wheel and ground off the rivets that were holding the fender drain piece in place....then replaced them with the Panhead screws. From Lowes.......
This is the car as of today:
For some reason, the radio had blown a fuse, so we went ahead and replaced it. we now have a working stereo!
The back carpet was about the same as the last time you guys saw it, so I glued down the passengers side. Since the trim had been painted, I went ahead and installed it.
As you can see, it came out nice. Now, I need to install the center piece of carpet in the rear, and finish the storage doors. Also, I need to install the drivers side carpet. This would get it to a point where we could at least get some seats in it and drive it. So, that's all for now.
As you can see, there are still vacuum issues
That's it for now. Hopefully, I can solve some of the wiring issues tomorrow.
Hopefully the glue doesn't work to good and you can still do it........WELL worth the money......some of the best money I spent on our car.
