1971 Windshield trim
Old Apr 24, 2012 | 07:10 AM
EngineerJay's Avatar
EngineerJay
Default 1971 Windshield trim
My '71 has a non stock hood, but I got the stock hood when I purchased it. I am in the process of getting ready to switch so I ordered some trim pieces that I was missing. They go along the front end panel up against the windshield.
I was trying to place them last night, and noticed that the screw hole is there for the side of these pieces, but I cant find where I am suppose to put the clip.
http://willcoxcorvette.com/product_i...oducts_id=1862
this is the trim piece I am talking about, according to the AIM I think I know how it goes, but I think the previous owner trimmed back the fiberglass for some reason so now there is nowhere to clip these things to. I will post pictures of this spot tonight, until then, any ideas on what i can do?
Thanks,
Jay
Old Apr 24, 2012 | 07:52 AM
BBCorv70's Avatar
BBCorv70
There are a couple clips on the top edge of the fender and a screw on the inner side. Maybe Alan71 has some photos? I could post a few if necessary but won't be until late tonight.
Old Apr 24, 2012 | 08:03 AM
Roco71's Avatar
Roco71
There are two clips that hold the corner trim in place. There should be two holes that the clips lock into that keep them from sliding out while holding the trim.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Apr 24, 2012 | 08:13 AM
EngineerJay
I have the screws and the clips, I just am not sure where they clip onto. The area that I have available for them seems too thick on the fiberglass for these clips to go onto.
Thanks,
Jay
Old Apr 24, 2012 | 09:19 AM
Mooser's Avatar
Mooser
You can kind of see the clip here in the "didn't get removed before paint" picture
There are more clips along the wiper door, those might be thinner (don't know) than the ones on the fender?
Mooser
Old Apr 24, 2012 | 09:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The fender should have a hole for a u-clip where the fender top trim slips down into the hood opening. AIM will show a trim screw into the clip. You'll have to open the wiper door.
Old Apr 24, 2012 | 10:21 AM
EngineerJay
Thanks for the picture Mooser, my problem is now that someone either "removed" the portion of the fiberglass that the clip goes onto or put something behind it, or I am just crazy and it is fine. I did manage to find a picture that i had taken that shows the area.
If it is messed up, any ideas on how to get the trim attached?
Old Apr 24, 2012 | 11:33 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by EngineerJay
FWIW: You need to line up that fender before worrying about getting the trim on it. What's the story here? Are you in the process of installing the front clip?
Old Apr 24, 2012 | 11:43 AM
EngineerJay
Not installing anything but the trim and the stock hood. I haven't touched any of the body. I know the hood, vents, and wiper door fit nicely when installed, i just wanted to complete the look with the side trim.
So, if its not aligned, how bad does it look?
Old Apr 24, 2012 | 12:01 PM
Easy Mike's Avatar
Easy Mike
...So, if its not aligned, how bad does it look?...
Is the door open a little in the pic?
Old Apr 24, 2012 | 12:46 PM
EngineerJay
Yes, the door is open a little bit.
Old Apr 24, 2012 | 12:48 PM
Easy Mike's Avatar
Easy Mike
Thank you. That explains the gap.
Old Apr 24, 2012 | 06:13 PM
Alan 71's Avatar
Alan 71
Hi,
Here's a picture that shows the holes the tabs on the bottom of the clips grab on to.
It looks to me like the 'lip' on EJ's fender has been 'modified', perhaps to match the rear of the long hood?
Regards,
Alan
Old Apr 24, 2012 | 07:13 PM
Clubby99's Avatar
Clubby99
I'm also in the middle of a conversion. Your problem is the same as mine. The corners of your fenders were "built up" to match the later year hood. You will need to do body work by grinding and shaping the excess?
Do you have the wiper door and parts?
Old Apr 24, 2012 | 08:31 PM
BBCorv70's Avatar
BBCorv70
Looks like the door linkage is still there. Has the front clip been changed? Do the fenders have egg crates? Wondering if the PO modified the fenders or may have installed a later year front clip..
Old Apr 25, 2012 | 07:13 AM
EngineerJay
So I am going to have to start removing a little paint at that spot huh... not exactly what I wanted to do.
Alan, do you know roughly the dimensions of where the first clip is from the outside edge and how wide the lip is?
Clubby, I do have the wiper door and other parts.
BBCorv, I have the egg crates still, so I am pretty confident it is the right front clip.
Thanks,
Jay
Old Apr 25, 2012 | 07:24 AM
Roco71's Avatar
Roco71
I had to cut the fender corners off my car to repair the birdcage and then glass them back on after the repair. Upon doing that I bonded the gap between the fender surround and the inter cowl corner which is were the clips fit. I used a Dremel with a cutting disc to re-cut the gap for the clips.
To 1971 Windshield trim
Old Apr 26, 2012 | 08:22 AM
EngineerJay
Unfortunately after looking at it closer last night, it appears that it was not built up, but an attempt was made to sand it down to match the hood.
This is the only close up picture I have that includes the hood and the side. The hood is far shorter so someone attempted to make the sides match. My original hood is pretty beat up so I was planning on taking it in to get fixed up and repainted to match so I might see if the shop can also do a bit of glass work too. I would try.. but I have never worked with fiberglass before and am hesitant to try right now.
Old Apr 26, 2012 | 08:58 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If the trim pieces look good placed on the fender lip and your only concern is the clip attachment an easy fix might be to epoxy them to the fender.
Old Apr 26, 2012 | 09:37 AM
Roco71's Avatar
Roco71
I was sort of thinking the same thing. From the photos it really does not look like much material is missing from the corners. You might have a better idea when you get the wiper door installed as to how thing will line up.
