Coolant leak - 1969
Old Apr 25, 2012 | 03:05 PM
Dalm's Avatar
Dalm
Default Coolant leak - 1969
Hey gang,
I'm a bit of a novice. My 1969 is leaking coolant on the ground on the passenger side near the side pipe. Now car running too hot. The car had some work done and the coolant topped off. I thought it could be overflow, but too much came out and the engine to hot. Any help on what could be causing it and how to fix would be appreciated. Dan
Old Apr 25, 2012 | 03:17 PM
JimT's Avatar
JimT
What kind of work was done on your car? Radiator? Water pump? Heater? That info may help in a diagnosis.
Old Apr 25, 2012 | 03:53 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sounds like heater core to me. Have you crawled under to take a look?
Old Apr 25, 2012 | 03:55 PM
Trucks_69's Avatar
Trucks_69
what mike just said... i'd deff jack it up and inspect it
Old Apr 25, 2012 | 09:42 PM
Dalm's Avatar
Dalm
I had heads and intake removed and painted. I'm thinking the problem could be the thermostat not functioning properly? May not be opening up and causing overflow to kick in and lose fluid?
Old Apr 25, 2012 | 11:04 PM
ezobens's Avatar
ezobens
You had the heads and intake removed just to have painted?!
Yikes... Breaking open engine seals is not something I do unless it's absolutely necessary.
My money is on incorrect gasket installation or prep and now you have a head or intake gasket leak.
Elm
Old Apr 27, 2012 | 09:42 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
To Coolant leak - 1969
