Battery drain
Old Nov 17, 2013 | 03:49 AM
galeel's Avatar
galeel
Whats the update? I have same problem,when i charge the battery with jumber, the. It fires up,however, the corvette suddenly shuts down after driving for small distance !!!!?
Old Nov 17, 2013 | 08:47 AM
Jedi926's Avatar
Jedi926
Good morning Galeel. I traced the problem back to my new choke, it was still getting power. I made sure all the connections were good then changed a fuse and problem corrected. I still have not put on the battery disconnect but for short money it is worth it instead of having to deal with a dead battery. Good luck man.
Old Nov 17, 2013 | 09:05 AM
galeel's Avatar
galeel
Why the corvette suddenly shuts down while driving?
Plz note i have new alternator.
Old Nov 17, 2013 | 05:58 PM
bruisedknuckles's Avatar
bruisedknuckles
Galeel, it turned out to be a bad 'positive battery cable'. Hooked a jumper from the positive terminal directly to the starter and the car would start up every time I did this. Swapped out the cable with a new one and have had no problems ever since. Hope this helps.
Old Nov 18, 2013 | 10:36 AM
tomgallucci57's Avatar
tomgallucci57
on my 68,if you dont cycle the wiper motor properly,,it will drain the battery.
Old Nov 18, 2013 | 01:52 PM
galeel's Avatar
galeel
How. Do u cycle the wiper motor,btw my wiper is not working
I tested battery for drainage but didnt find any!
Old Nov 19, 2013 | 10:45 AM
tomgallucci57
i sent you a p.m.....
Old Nov 19, 2013 | 12:34 PM
Kacyc3's Avatar
Kacyc3
Mine was a factory alarm was draining due to bad door jamb switch.
