Need to repair the mounting holes for the shifter plate to be attached. I bought a repair kit for this purpose. Anyone install this kit? If so any pictures. Do I just hot glue the brackets to the under side? Seems ovious this how, but checking. Also I noticed the on the forward brackets, they will cover the mounting holes for the fiber obtic bezel. I fiigure I just need to remove or drill a hole to allow the potrusion to pass through. Well any advise would be appreciated. Sorry my spell check was not working.
I have done the repair and it is installed so no pictures. If I recall, the hot glue did not hold and I ended up using JB Weld. One it was cured it was perfect.
