Alternator
Old May 4, 2012 | 11:22 AM
  #41
noonie's Avatar
noonie
First , with the key in the ON position, check that your idiot lite(s) come on in the dash.
If not, then check fuseable links at the starter bat terminal (large).
If so, then check with a test lite or multimeter the purple wire that goes to the starter solenoid for power, or you can reach down and short the solenoid bat terminal (large) to the small solenoid terminal (with the ignition off). It should crank and not start. Doing this with the key ON, it should start. With key on, make sure it's in neutral or park.
If no power to the purple start wire at the solenoid, then backtrack to the neutral switch, then the ign switch.
If using a voltmeter, there should be no more than 1volt drop from battery voltage to the solenoid purple.
If more, then you have bad switches or connections/wires.
If you can get the solenoid to at least click with proper voltage, then you have other issues to pursue.
Old May 4, 2012 | 12:20 PM
  #42
Spocc's Avatar
Spocc
Originally Posted by Maymyvetteliveforevr
Pete:
Sorry but Mick has my car so I'm not able to come and help as Cathy has the other car.
The purpose of a safety nuetral switch is to dissengage power to the starter when the shifter is in any gear to prevent accidental starting while in gear. Sometimes when this particular switch starts to wear you can still start the car by turning the key ignition to the start/on position (as if to engage the starter) at the same time move the shifter up and down between park and drive, if the switch is worn there is a chance the car will still start.
Yes there should be either a fuse at the fuse box or an inline fuse, inline fuses are actualy in the middle of a wire run. I can't remember if your year has one.
Pete, did you disconnect the battery when you changed the alternator, reason I ask is maybe something got grounded if it wasn't disconnected and shorted?
If you don't mind can you also double check the connections on the rear of the alternator, there should be a harness and another wire that's bolted on.
If you're able, can you check for power to the starter, in order to do this you will either have to get a multimeter, or cross the terminals on the starter solenoid and just above the starter where the wires connect to? It's on the passenger side rear of the motor. You can see it at the bottom just in between the engine and transmission. If you have a multimeter, see if someone can engage the starter via the key and check for power to the starter.
When you said, "this car has done this to me before" are you refering to this particular problem or reliablility in general?
never had a starting issue for over 5 years
battery was out of car when i swapped the alternator
going down now to pull a few fuses & check moving shifter when turning key
i have 3 12 hour shifts to do (Friday, Saturday & Sunday 6:30pm-6:30am) at Emergency Dispatch , so i won't be back at this until Monday night
not to worry i have 2 bikes to ride so life is still good lol
thanks Frank
Old May 4, 2012 | 12:22 PM
  #43
Spocc's Avatar
Spocc
going down to swap a few fuses
where are the fusable links at starter bat terminal ? i'll look for something large
Old May 4, 2012 | 12:45 PM
  #44
noonie's Avatar
noonie
At the starter.
If you have power to the Bat terminal on the alternator , the link should be good.
Old May 5, 2012 | 01:49 PM
  #45
Spocc's Avatar
Spocc
the Batmobile lives !
it was the f***ing battery , all along.
the little charger i use has a gauge , which has a red zone, then a green zone.
i had assumed that because it went into the green zone , the battery was ok...doh
thinking about the entire circus act i have been thru in the last week i decided when i got home from work at 7am that just for ***** & giggles i would take my spare boat battery down to the car & even tho the neg /pos connections were not correct i took a couple of vise grips with me....the boat battery , after jury-rigged behind the drivers seat , fired the beast, immediately
so over to Can Tire to get a replacement (it was a Nascar battery purchased 2 years ago, with a 4 year full replacement warranty.
ya hooo !
logical dictates that i need to buy one of those volt-tester gizmos lol
thanks for everyones help on this one & keeping me encouraged to keep at it
Pete.
Old May 5, 2012 | 04:06 PM
  #46
73Corvette's Avatar
73Corvette
OOoohh head out on the hiway...
OOOoooohhh head out on the hiway.........
Old May 5, 2012 | 05:15 PM
  #47
Spocc's Avatar
Spocc
will be driving it to work in an hour...12 shift & a full moon....fun wow !
Old May 5, 2012 | 08:22 PM
  #48
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Pete,
I missed the original posting of your thread. Glad things worked out for you. I replaced a fuel pump last year only to find all I needed was a new filter. At least you needed both problem parts. Good job, back on the road again!! Take care bud.
Terry
Old May 5, 2012 | 08:55 PM
  #49
boeing46's Avatar
boeing46
Spocc, Very glad you got it. I once spent a whole weekend at a Chevron station I worked at trying to figure out why my 59 T-Bird wouldn't start. It was out of gas. I think we've all been there done that. We have to remember the old rule to keep it simple.
Old May 5, 2012 | 10:43 PM
  #50
Spocc's Avatar
Spocc
Originally Posted by HOOAH
Pete,
Terry
maybe the failing battery caused the alternator to work harder ...
maybe i turned in a perfectly good alternator...
But, now i have a new battery & a new alternator & taught myself a new learning curve
thanks Terry, will have to remember the fuel filter thing, if that ever comes my way (car or boat...boat has a 327 4B )
Pete.
Old May 5, 2012 | 10:49 PM
  #51
Spocc's Avatar
Spocc
wouldn't want to do that with an airplane...
you are correct - keep it simple
thanks !
Old May 6, 2012 | 05:57 PM
  #52
Maymyvetteliveforevr's Avatar
Really glad it worked out Pete.
As for your alternator, next time you're at Parts Source or possibly where you purchased the rebuilt have the old alternator tested. If it's good then keep it as a spare or maybe other member maybe in need ot it one day.
Old May 6, 2012 | 06:24 PM
  #53
73Corvette's Avatar
73Corvette
Here ya go again Pete......a day late, and a dollar short....
Old May 6, 2012 | 06:51 PM
  #54
Spocc's Avatar
Spocc
its been a good week-end, i drove the Batmobile to work again tonight...fires strong & runs perfect...life is good ...don't have to worry about cranking the tunes with a brand new battery & alternator
thanks again guys !!!
Old May 7, 2012 | 08:31 AM
  #55
gdh's Avatar
gdh
Glad it all worked out Pete, my next place will have a garage big enough that I'll be able to put a lift in so I can get under the vette without doing my back in. I've had some batteries last 10 yrs other barely make it through 2. Have to take mine over to Midas as a clamp must have let go just as we were lag Thornbury yesterday- made a hell of a racket banging underneath until I could get up to speed and away from that pulsating lope at low rpm.
Hope to see you both again this summer.
Old May 7, 2012 | 01:48 PM
  #56
Spocc's Avatar
Spocc
yes Greg
Nancy & i would love to cruise with our C3 buds again
yer 72 behind me there...that was a delightful run, lead by a gracious host
i haven't heard from Todd in awhile, everyone else has been on the forum
thats Todd in the #3 car, i've nicked him "the intimidator"
