Carpet glue?
Old May 1, 2012 | 05:44 AM
Gordonm's Avatar
Gordonm
Default Carpet glue?
What are people using to glue the carpet to the floor if anything. Putting in a new carpet while the interior is out while doing the LS3 swap. At the point of getting it back. I have Cool Mat down on the floor for sound and some insulation so it is foil backed so that is what the carpet will be on.
Old May 1, 2012 | 07:24 AM
Clams Canino's Avatar
Clams Canino
3M spray adhesive.
-W
Old May 1, 2012 | 07:41 AM
sweeet76's Avatar
sweeet76
I agree. This while I'm at it is getting expensive isn't it. Always does.
Old May 1, 2012 | 07:54 AM
73Corvette's Avatar
73Corvette
I didn't glue mine down......it's such a pain to get it back up....it doesn't move anyway...but, mine is the original and is very well molded to the shape of the floor boards and other contours.
Old May 1, 2012 | 08:17 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Didn't use any glue on my carpet. Has been down about 10 years now with no problem.
Old May 1, 2012 | 08:30 AM
Alan 71's Avatar
Alan 71
Hi,
I used very little glue on the carpet also.
I think it's best held in place by the seats, console, and trim panels.
On my 71 the rear wheels wells had some glue on them, but that's the only place.
Regards,
Alan
Old May 1, 2012 | 09:13 AM
jnb5101's Avatar
jnb5101
the factory used beads of adhesive (think construction adhesive caulking gun) on the wheel wells.
Old May 1, 2012 | 09:15 AM
69 Chevy's Avatar
69 Chevy
I used Weldwood contact cement to glue my carpet to the foil-faced heat barrier. Bought from McMaster-Carr
in Robbinsville, NJ.
Bonds metal, plastic, leather, paper, rubber, and wood.
Old May 1, 2012 | 11:44 AM
Vette5.5's Avatar
Vette5.5
Agree, you probably don't need much adheasive, but a little 3M Super 77 spray on both surface sides in the corners probably wouldn't hurt, because of the slick foil face sound material. Not sure of the Weldwood contact cement though, as tends to dry out and crust up over time.
Old May 1, 2012 | 12:44 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by Clams Canino
3M spray adhesive.
-W
thats what i use ...there are two different types....one is repositionable the other is not. so for areas that you can get right the first time you can use the permanent one. mostly i used the repositionable one
Old May 1, 2012 | 06:12 PM
champs65's Avatar
champs65
In my honest opinion, the 5 dollar a tub carpet adhesive from Lowes/HD/etc. works very well. Easy to apply where you want it and in the quantity you want it; has a long work time, and gets VERY tacky/sticky after about a day.
And it's cheap
Old May 1, 2012 | 07:13 PM
scottyp99's Avatar
scottyp99
Why on Earth would you want to glue down the carpet? Why don't you weld your valve covers on while your at it. Say, that might not be a bad idea, it would sure keep 'em from leaking........
Keep the shiny side up!
Scott
Old May 1, 2012 | 07:20 PM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
Mine isn't glued anywhere, there's just so little of it left after interior reinstallation that it doesn't budge.
Old May 1, 2012 | 08:44 PM
bobs77vet's Avatar
bobs77vet
Originally Posted by scottyp99
Why on Earth would you want to glue down the carpet? ........
Scott
to stop it from moving and causing ripples
Old May 1, 2012 | 08:59 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
I was planning on gluing mine, but it fit really well and by the time you put trim and seats and stuff in, it can't go anywhere...
(thanks, Wilcox)
Old May 1, 2012 | 10:03 PM
Shark Racer's Avatar
Shark Racer
I've used 3M Spray Adhesive and Loctite Carpet adhesive with good success. The loctite worked better for me, but there was a 5-10 year gap and my "car skills" had leveled up a lot so that may account for it.
Old May 1, 2012 | 10:10 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
To Carpet glue?
Old May 1, 2012 | 10:46 PM
Gordonm's Avatar
Gordonm
Thanks for all the replies. The carpet near the forward hump and foot wells is what I am worried about. Just don't want the bunching and or movement up front.
Old May 1, 2012 | 10:52 PM
73Corvette's Avatar
73Corvette
Small beads of glue......only where you need it.
Old May 3, 2012 | 09:20 AM
69 Chevy's Avatar
69 Chevy
Do you have this kind of foil-faced sound/heat barrier directly under your carpet? Perhaps you still have have the jute backing which isn't slippery?
