dumb question ?
Old May 1, 2012 | 08:58 PM
lowes-yellow77's Avatar
lowes-yellow77
Default parts list
ive always been told only dumb question is the one not asked...
is there a corvette specific shifter for a 4 speed? im doing the swap and gathering parts slowly... i went to buy the linkage and it says only up to 76 is the same for the shifter and linkage. any quick answer would be nice thank you
Last edited by lowes-yellow77; May 17, 2012 at 10:25 PM. Reason: changing title for parts list
Old May 1, 2012 | 09:18 PM
markids77's Avatar
markids77
You will need to match the shifter to the transmission you end up with.... for instance a Muncie shifter probably will not fit a Saginaw trans. Post up your parts list, and I'm sure someone here has used almost the exact same setup.
Old May 1, 2012 | 10:15 PM
ATIS's Avatar
ATIS
Depending on the tranny I know in 1975 there are two different shifts that are 'stock" and then Hurst makes an aftermarket one.
Old May 2, 2012 | 05:49 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
in addition to the above "suggestions", the important thing to keep in mind (at least in the later c3s) is that the shifter mechanism is slightly off set toward the drivers side of the transmission. virtually all the OEM GM 4 speed shifter mechanisms will work, but using the correct mounting bracket (shifter to transmission) is the key. in addition, you will need to open the tunnel up on the left side to accommodate the shifter. it doesn't fit through any opening that might be there for the automatic (if there is any at all since it is cable connected), and don't forget the lower shift boot mounted to the tunnel.
Old May 2, 2012 | 06:16 PM
BBCorv70's Avatar
BBCorv70
All Corvettes I've seen have a bracket, bolted to the transmission crossmember, which the shifter mounts to. I've never seen a factory installation with the shifter mounted directly to the transmission.
There is an inner and outer boot. The inner, rubber, mounted to the tunnel over the shifter, outer, leather, attached to the console shift plate.
Do you have an AIM? This will tell you exactly what was used to mount the shifter for factory installed 4 speeds. I've never heard of any mods needing to be done to the tunnel other than situations where an automatic was installed.
I'm most familiar with 67 - 73 Corvettes. It may be possible the later years are a bit different?
Old May 17, 2012 | 01:28 PM
lowes-yellow77
Default parts list
do you guys know if a hurst shifter 391 5103 will work for the c3 vettes it looks like there all the same on hurst website
To dumb question ?
