Do you just park your vette on the garage floor or?
St. Jude Donor '12
It goes on with a roller just like paint. Has the look of a dealer showroom floor. Easy to clean, doesn't chip or come up. The secret is to PREP the cement the correct way prior to install. I have spilled all kinds of liquids even muriatic acid. Just wipe up. I also have drooped hammers and things with no troubles. Plus once it's done. Never have to deal with it again.
it is a 65 with a 72 nose,72 back window, tail is custom, L88 stile hood. just a real old custom.
I put cardboard under my car and then duct tape the edges down so it doesnt move. Part of this reason is that it will catch the various drips, leaks or cleaning if I move the car around the garage some. Also, it helps with the cleanup. Since the cardboard will also absorb some of the liquids I may use when doing brake jobs, oil changes, etc, it can then be easily removed and disposed of. Keeping the garage clean, and reducing the amount of cleaning materials and rags I may have to use other wise.
kdf
kdf
Vinyl flooring rolls ...got em from Costco online. Huge diff....if for nothing else then for those times u want to kneel down next to the car or look underneath while still in u'r good clothes. Plus it keeps down the moisture from the cement.
Here it is under the vette & the unfurled roll is next to the GrandmaMobile waiting to be installed.
Painted concrete and a strip of carpet under each C3. They do not leak, just there to absorb in case they do. The space rug between the 68 & 73 is for my yellow lab when he works with me in and around the cars
On an old "Indian Rug" from Pakistan...my parents had it downstairs and unfortunately, mice got at one end which was by the wall...so, instead of throwing it out, under the car it went! Looks classy on the carpet in our garage.
Domer.
Domer.
#34
I'm a big fan of carpet, very comfy when working under the vette.
#35
i live on the 35th floor of a 44 floor , twin-tower complex
the underground semi-heated parking, is larger than the flight deck of an aircraft carrier & the floor is this black material
best part is the coin car-wash, at the one corner, open 24/7 ...no excuse for a dirty machine
oh & security patrol 24/7 on electric golf-carts...don't even hear them coming
Pete.
Pete.
#36
Well, from what I have learned, a large plastic sheet on a cement floor will prevent moisture from coming up. I also placed carpeting over the sheet and both are wider and longer than the vehicle. My garage is also heated so I guess that helps. Liked some of the floors I saw. Might go with the expoxy.
#37
#39
I put the epoxy down when we first moved in and I am completely hooked. I've had various 'drips' from the Vette and other items that wipe right up even if they've been on the ground for 2 weeks. I still place a piece of cardboard under the car just to save the wiping up, but I'm no longer concerned about any spills or leaks. Best $150 I could have spent.
#40
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
