stuck rings in junk yard engine-help
Old May 12, 2012 | 04:47 PM
LT1driver's Avatar
LT1driver
Default stuck rings in junk yard engine-help
can turn motor over but it is very hard even with plugs out, only turned about 2 inches before i stopped for fear of running something .... what is best way to free stuck rings or do you think it is something else, been sitting inside for 4 years, motor running when parked in storage building, sat with oil in motor and water in radiator, no indication of water being frozen, no cracks in block etc. thanks for help and ideas.
Old May 12, 2012 | 04:54 PM
Scottd's Avatar
Scottd
Trying to turn an engine over by hand, even with the plugs out, takes some muscle. How are you turning it? If you are going by hand or a socket on the crank (Bad idea btw) its going to take some effort. If it is indeed stuck, Fill the cylinders with transmission fluid and hand rotate it a few degrees every hour. If they are indeed that frozen, shes going to need a rebuild anyways. Good luck.
Old May 12, 2012 | 06:18 PM
LT1driver's Avatar
LT1driver
how would you suggest I turn it over and why is a socket and breaker bar on crank bolt a bad idea to turn 90* at a time?????
Old May 12, 2012 | 06:33 PM
Scottd's Avatar
Scottd
The bolt can actually break off inside the crank. Big mess. That being said......I do it all the time. 1/2 inch breaker bar and a cheater pipe and very slow rotations, maybe 10' at a time. (They also make a tool to attach to the crank, but Ive just used the above method) However, if its really tight, try a strap wrench around the crank pulley as well. A screwdriver tip in the flywheel also works.
Old May 12, 2012 | 06:40 PM
7T1vette's Avatar
7T1vette
Remove plugs, shoot lots of PB Blaster or squirt lots of Liquid Wrench into each bore. Shoot it at the inner wall of the cylinder, since the heads of the piston slant towards the 'outside'. That should get the upper rings 'juiced up'. Let it sit for a few hours, then shoot it again. Repeat for a couple of days without trying to turn the engine.
Then, use a breaker bar with a socket on the crank (damper) bolt...but don't go nuts with the amount of torque applied, or you may break the bolt head off.
Whether you get it to free up or not, you probably should NOT try to fire this engine. The rings were likely corrosion-welded to the cylinder wall and have done some amount of pitting/damage. If you fire it with that on the cylinder walls, you may just gouge/score up the walls. It would be better to pull the pistons and hone the bores....if they aren't too badly corroded. The rings need changing, anyway.
Old May 12, 2012 | 06:47 PM
Mark-Ia's Avatar
Mark-Ia
A 50/50 mix of Automatic transmission fluid and acetone is the best penetrating oil you can get.. Put some down each cylinder, let it set a couple of days. It will work wonders..
Old May 13, 2012 | 12:36 PM
jesse10886's Avatar
jesse10886
Good luck if it only sat a few years you could be fine in a few days of lubing it up
We had a 59 apache that sat in a field 20years. Rats eat all the wiring tranny fluid acetone new plug wires an direct distributor and starter to battery blew all the fluid out the top before putting plugs back in ran good for over a year then we rebuilt it all
Old May 13, 2012 | 01:59 PM
Mark G's Avatar
Mark G
When I was a kid I bought several engines that had sat for years and we put them in and ran them. One sat under a tarp with lots of wood (split lumber for burining) on top of it. I think it had sat 10 or 15 years. I think I might have put oil in the cylinder, I don't remember being too concerned if they turned over that much. I might have just fired them up being a kid and all. Anyway, never had problems with the motors I bought used, ironically. But those were tough Ford 289 and 302 engines (oops, did I say that?). You'll mostlikely have some pitting on the walls, but if it's going to be a trailer queen and not get very many miles on it, maybe it doesn't matter. If you are going to rely on it and put miles on it, yeah, I'd at the very least pull the cylinder heads and see what the cylinder walls look like. Wouldn't take much to yank it, hone it, new gaskets and paint and look fresh again.
Mark G
Old May 13, 2012 | 05:50 PM
RIO68's Avatar
RIO68
Just remember, you don't pull it all in one direction, you put some type of lube, as many different ideas as people you ask about which is the best, in the cylinders and with the breaker bar and socket, by the way I have never broken the bolt on one, you pull it one direction and then back it up--each time try to gain a little distance be it only 1/2 inch or less but just continue the process and it will break free for a complete revolution of the crank. It can take a boat load of time to do some of them. If it doesn't then you have something internal that will mean you will have to tear it down. My 2 cents!
Old May 13, 2012 | 06:57 PM
73Corvette's Avatar
73Corvette
Marvel Mystery oil .........
Old May 13, 2012 | 08:10 PM
Billysvette's Avatar
Billysvette
I second this one,really works great.free those rings right up.squirt or spray it in the cylinders and let sit couple days to a week.
Old May 13, 2012 | 10:18 PM
markids77's Avatar
markids77
FWIW valves can stick in the guides as well. I bought a 71 Triumph TR6 as a much younger and less experienced man and pulled hard enough on the crank bolt to break a rocker arm while trying to get the engine to turn. I then pulled the rocker shaft and lubed each stem, then bumped each with a brass drift and hammer untill they all bounced freely. Replaced the rocker, adjusted the valves and that engine ran as sweet as honey. Just another thought.....
Old May 14, 2012 | 06:06 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
this is probably the best way to try to free the engine up. since you are probably looking at a rebuild, the key is to reduce the cylinder wall damage as best you can. that is why you don't want to crank it very much with each attempt. once it does break free, it will undoubtably scratch the cylinder walls as you rotate the crank. keep it to a minimum and you can't use too much penetrating oil on this job.
To stuck rings in junk yard engine-help
