C3 dash pad installation tip
Old May 14, 2012 | 09:11 PM
Mayan2012's Avatar
Mayan2012
Default C3 dash pad installation tip
I recently removed my upper dash pad for repair. The dash pad is difficult to remove and replace without bending or bowing it. The pieces that get in the way are the triangular tabs that sit behind the pillars. I used a dremel and removed the hard plastic on the underside of the tabs and even some of the foam. In doing so, it allows the tabs to bend so that it clears the pillar and does not effect the outward appearance.
Old May 17, 2012 | 10:07 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Thanks for the tip.
Old May 17, 2012 | 10:28 AM
MrJlr's Avatar
MrJlr
I'm looking to do this soon......did you take some pics ?
Old May 17, 2012 | 11:08 AM
jcloving's Avatar
jcloving
Here's how I put in my new dash pad:
I put in the drivers corner first.
I put a microfiber cloth (any type would work) on the pass. side corner.
Place pass. side against the pillar and gently bow the middle up about 1-2 inches.
In so doing, I was able to gently move the pass. side corner past the pillar and into place.
I could then drop downt he dash in the right spot.
I did this about three times when I rebuilt my interior. The new dash pad has a large ABS plastic backbone and can be flexed with no problem.
Old May 17, 2012 | 11:36 AM
jesse10886's Avatar
jesse10886
Awesome thread all we need is pics
I am hoping to do this to mine soon thanks for the tips guys!
Old May 17, 2012 | 03:58 PM
Paul L's Avatar
Paul L
What vendor did you use to get the ABS backbone?
Old May 17, 2012 | 04:32 PM
jcloving's Avatar
jcloving
Ecklers:
http://www.ecklerscorvette.com/corve...1970-1976.html
It was a thick black ABS plastic piece that the foam and then the vinyl were bonded too. Stiff but I coud bend it like a bow when installing it in the car. It will last for years and years.
Old May 17, 2012 | 06:07 PM
Mayan2012's Avatar
Mayan2012
Sorry, I never took any pics. I took my dash out to repair a crack in the outer vinyl. The solid core piece (plastic, fiberglass, ABS?) under the vinyl and foam was cracked in a few places as well. Looks like the previous owner did a job on it. I have come to understand that some older dashes can become brittle which is why I did not want to bow it in the middle to get it to go in. I thought my solution, although minimally destructive to the underside, was a good precaution to prevent further damage.
Old May 17, 2012 | 07:19 PM
Zorro O's Avatar
Zorro O
I just happened to pull my dash off today and have a tip.
Put the headlight and wiper switches back together and just let them hang till you go to reinstall the dash. After pulling the dash start the car and you may hear vac leaks you never heard before. I started mine and discovered a vac leak at the light switch. I also found out why my wife is always so much colder than me in the car. Someone had put the dash in, and left out the air duct for the passenger side. I may replace it, or not.
Zorro
Old May 17, 2012 | 08:14 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
These pages will help anyone pulling the pads from their car. All the new repro upper pads are ABS backed.. and they fit great!
I posted both links but the trick is that when you get to the left pad on the first help page.. stop and move to the the second one... The original one about all the pads needs a revision that the second one covers.
Corvette Dash Pad Remove and Install Instructions 68-77
Corvette Left Hand Dash Pad Removal Made Easy 1968-1977
To C3 dash pad installation tip
