Under the ashtray
Old May 15, 2012 | 11:29 PM
TO_Vette's Avatar
TO_Vette
Default Under the ashtray
I pulled the ash tray out and looked under it and seen what looks like a plug that something should be plugged in.
Am I correct, if so what plugs into it?
Old May 16, 2012 | 12:47 AM
SIXFOOTER's Avatar
SIXFOOTER
guessing you have an 81, that would be the ECM connection for diagnostics
Old May 16, 2012 | 09:31 AM
golfradict's Avatar
golfradict
You can find a good shop manual for your year corvette on ebay. My 81 has this connection (81 was the first year for the corvette ECM) The shop manual will show you exactly how to do a "Diagnostic Circuit Check" if your check engine lamp comes on.
Old May 16, 2012 | 09:38 AM
qwank's Avatar
qwank
Yup, its the DLC. if you jump the two terminals on the left you can flash trouble codes through your check engine light. A good way to check if your system is operating properly is to jump them and see if it flashes only a code 12. If you have just a 12 your system should be running well.
To Under the ashtray
