1982 Distributor cover
Old May 17, 2012 | 07:21 PM
Jfeelgood04's Avatar
Jfeelgood04
Default 1982 Distributor cover
The first time I saw that weird cover I thought it was a Bubba piece. Two questions...is 1982 the only year that had that and does anyone have a pic of a replacement for that? The stock piece really looks amateurish.
Old May 17, 2012 | 08:48 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I believe that RFI sheild was used from 1980>82. I've never seen a replacement offered for sale.
Your right it isn't the best looking piece but it does get the job done.
Pic of my 82CE
Old May 17, 2012 | 09:43 PM
terry82's Avatar
terry82
i have thought about making a metal one that would look like the ones on the ones the c2s.
Old May 17, 2012 | 11:31 PM
gbvette62's Avatar
gbvette62
The black grained plastic ignition shield, was used from 1978-1982. The 82 shield is slightly different than the 78-81 shield.
On the earlier shields, there are 2 "ears" that go down behind both heads on the engine, and shield the plug wires on both sides of the engine. The 82 uses the same plastic shield, but one of the "ears", is eliminated. At the moment, I forget which side is eliminated, but I think it's the left side one.
There is a stanless piece, that has been sold for years, that can be installed on top of the plastic shield. It was even in the Corvette Parts Book and could be ordered from Chevrolet. It was never a factory installed piece though.
Here is the cover in Corvette Centrals catalog.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Old May 18, 2012 | 12:04 AM
TexasMadMan's Avatar
TexasMadMan
25 years ago when i owned an '82, I installed and earlier C3 chrome cover. I was able to make it fit in place and it looked much better than the black piece.
Old May 18, 2012 | 12:07 AM
gq82's Avatar
gq82
Learn something new everyday....BTW the 82 sheild was shorter on the passenger side of the sheild...it did not extend as far towards the engine block.
Old May 18, 2012 | 08:05 AM
Jedi926's Avatar
Jedi926
I got rid of my stock one and don't use a shield at all, no problems.
Old Jul 5, 2018 | 10:05 PM
ffarina's Avatar
ffarina
Default Spark plug routing
Do the plug wires go in front of the shield or behind it?
Old Jul 6, 2018 | 06:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ffarina
...Do the plug wires go in front of the shield or behind it?...
The stock shield fits over the plug wires.
Old Jul 6, 2018 | 08:56 AM
ffarina's Avatar
ffarina
Ok so the wires go under the shield between the shield and the engine block.
To 1982 Distributor cover
