700R4 question
Old May 20, 2012 | 08:03 PM
alconk's Avatar
alconk
Default 700R4 question
Ok this is driving me nuts. I have a 82 with the original 700R4 and the lockup does not engauge. Sometimes it will when I first start it up for the first time of the day and it reaches temp but will immediately disengauge. I replaced the solenoid, the TCC switch and the 4th gear switch. The tranny shop told me that the computer wasn't sending the ground to the solenoid. They told me it could be fixed for $200 but then said they wouldn't garantee it. When I asked what they were gonna do he said it was a secret. Because of that I did not have then touch it. So after replacing those items could it be something in the ECM or PCM whatever you want to call it??? Other than that the tranny shifts great.
Old May 21, 2012 | 04:08 PM
DANNYS8's Avatar
DANNYS8
I have had 3 82's and the lock up even when it's working perfect does not work to good.It lock's up to early,then when u give it a little gas the engine shutters,just a nightmare.What I would do first is jump a wire between pins a and f on the diag connector behind the ash try .This is so easy to do this will force the converter to lock up.See if that works.That will prove if the tranny is ok.Then u can go from there Call me if u want danny 754-422-3497.I have been down this road many times.
Old May 22, 2012 | 12:12 AM
7T1vette's Avatar
7T1vette
It sounds like the lockup clutch is functioning in reverse of how it should. When cold, the L/U should NOT come on. When the engine is warmed up, it SHOULD come on. Perhaps the temp switch that sends the "warmed up" temp signal to the computer is wired backwards or the wrong unit was installed the last time it was replaced.
Old May 22, 2012 | 05:14 AM
terry82's Avatar
terry82
you made a good move ,stay away from a shop like that.does your speedo work okay ?that has to work for the trans to get a signal.
Old May 22, 2012 | 09:25 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
I had a similar issue. At speed the engine would cool so much that the clutch would disengage. Put in a slightly hotter thermostat and the problem went away.
Old May 22, 2012 | 12:09 PM
alconk's Avatar
alconk
I think I confused everyone. The lockup will engage for a couple of seconds on my first startup of the day BUT after when the car reached temp. Meaning it is warm. Sorry for the confusion. And thanks Dannys8 I will try that out today.
Old May 22, 2012 | 12:42 PM
alconk's Avatar
alconk
Yes speedo works fine
Old May 22, 2012 | 01:19 PM
alconk's Avatar
alconk
Yep it works when jumpered the "A" to the "F".
Old May 27, 2012 | 12:12 PM
alconk's Avatar
alconk
Well what I thought was fixed still isn't. But here are the clues. When A and F are jumpered the lockup engages, my cruise switch is adjusted right so that leaves me with a possibly bad ECM?? I don't know where to go from here.. Any suggestions??
Old May 27, 2012 | 02:50 PM
mrvette's Avatar
mrvette
I am not familiar with your stock '82, so question is.....do you have a 'external-inline' sending unit?? one that contains the sending coil and inserts itself in between the usual stock speedo cable and the typical tranny output from the speedo gearset??
THAT is what I had and just finished battling the thing....carefully open up the sending unit, mine was aftermarket.....look at the spinning magnet assy...you maybe well find that it's possible to activate your mechanical speedometer, and still have that magnet assy not spin...due to craziness of it's construction....drove me nutz for several days, me convinced with the temp, and intermittent operation that I had it fixed, but a day later it would not lock, especially on the freeway....it was giving the computer a very messed up, intermittent speed signal, while the dash looked normal....
I was ROCKET PISSED when I found it, talk about sneaky, that's IT!!!
damnit!!!!!
:hide :
Old May 27, 2012 | 03:51 PM
Drawmain's Avatar
Drawmain
I think that the speed sensor for the 82 is on the speedo itself in the dash, others will correct me if I am wrong. The signal comes from there and goes to the ecm. Check it out, there is a sensor attached to the rear of the speedo.
Old May 27, 2012 | 05:03 PM
terry82's Avatar
terry82
vss is on the speedo in the dash.
Old May 27, 2012 | 10:02 PM
alconk's Avatar
alconk
I really don't know how to check it but did have it unplugged and plugged it back in. Is there a way to check this?? I did recently buy a NOS speedo sensor in case mine was bad. Was told though that these hardly ever go bad...
alconk's Avatar
alconk
Could it be a bad ECM?
Old May 28, 2012 | 02:25 AM
Drawmain's Avatar
Drawmain
you plugged it in and it still won't lock up?
Old May 28, 2012 | 02:44 AM
alconk's Avatar
alconk
Correct
Old May 28, 2012 | 02:47 AM
alconk's Avatar
alconk
I'm thinking it's a bad ECM because one thing is the tranny shop told me the ECM was sending a intermittent ground and with all the other checks the lockup will work mechanically.
To 700R4 question
Old May 28, 2012 | 09:08 AM
themetalman03886's Avatar
themetalman03886
You could wire "A" and "F" together with a switch inline, might be a little ghetto but at least it will work and cheap at that.
Old May 28, 2012 | 09:31 AM
Drawmain's Avatar
Drawmain
Clean the connectors at the ecm first. If that doesn't correct it, then look for a new ecm.
Old May 28, 2012 | 11:42 AM
alconk's Avatar
alconk
Exactomunda...
