Squeaky Bushings
Old May 21, 2012 | 09:47 AM
Cal Vette's Avatar
Cal Vette
Default Squeaky Bushings
When going over bumps or rough roads the bushings are making a squeaking noise. Couple of years ago a shop sprayed some lub in them, it stopped for a while. Anyone have a pic or can tell me where they are under the car? What lubricant should I use?
Sorry guys..... just noticed I posted in wrong forum,needs to be in C5 section.
Old May 21, 2012 | 09:55 AM
oldalaskaman's Avatar
oldalaskaman
is it possible , you needed to post in C5? it also depends on which material your bushings are made out of. a neat trick used to be to drill the outer races for zircs and then just lube them , you dont see that much anymore, with the right stuff , of course
Old May 21, 2012 | 10:00 AM
jim-81's Avatar
jim-81
dang, nice avatar... just sayin.
Old May 21, 2012 | 10:08 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
No Kidding! I need to go lurking in the other areas once in a while. ha ha
Old May 21, 2012 | 03:32 PM
jcloving's Avatar
jcloving
One of the guys here added a grease fitting to the front sway bar bracket/bushing. He was running poly and said it fixed his issue.
Old May 22, 2012 | 02:06 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If poly, a generous coating of that super-sticky ES grease should make sure it's never noisy. Unless it's garbage poly.
To Squeaky Bushings
