Driver's Air Vent Replacement
Old May 26, 2012 | 05:20 PM
Karl Butz's Avatar
Karl Butz
Cruising
Default Driver's Air Vent Replacement
Hi All,
Can anyone explain how to easily get the old/broken, driver's side vent out and the new vent in?
Thanks! Karl
Old May 26, 2012 | 05:22 PM
briankeery's Avatar
briankeery
Old May 26, 2012 | 08:35 PM
PA14JIM's Avatar
PA14JIM
Well, if you are refering to the vent by the left foot. Remove the chrome ball and the plastic kick panel. Then you should be able to lift the door up and kick the bottom post out and remove the assy.
If you are talking about the eye ball vent it is removed from behind the panel, I think it was held on by 3 each 5/16" head screws. Will be a bear to work on without removing the entire panel.
Old May 26, 2012 | 08:43 PM
Greatsteaks's Avatar
Greatsteaks
I just installed a vintage air system. The drivers side ball is a bxxch to take out but I did it by lowering the steering colum and pulling the dash panel forward a few inches. Still wasn't fun.
To Driver's Air Vent Replacement
