Reverse flow sidepipe inserts
Old May 26, 2012 | 08:29 PM
scrappy76's Avatar
scrappy76
Default Reverse flow sidepipe inserts
I got a set off another member and installed them today. Pretty easy install The only issue was the pipes had a couple little bumps of weld slag inside the pipe, I had to reach in and file down. I did drill two 1/2" holes at the end of each insert to give it more of a beastly idle. and a little less restriction. I test drove around the block and was very happy.
Lol, alot quieter than open pipes. I know others have not liked them, but so far They are working for me. And the price was right.
