69 Vacuum Tank Question
Old May 29, 2012 | 01:19 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Default 69 Vacuum Tank Question
My 69 currently has the wrong 3 port vacuum tank. I have the correct 2 port tank but want to powder coat it before I swap them out.
My question is - is there anything inside that I could damage by subjecting it to the 400 degrees necessary to cure the powder?
My assumption is there is nothing inside but better to ask first! I am sure someone has had one of these apart.
John
Old May 29, 2012 | 01:36 PM
Alan 71's Avatar
Alan 71
Hi John,
I believe the tank is empty. No valves or anything like that!
Regards,
Alan
Old May 29, 2012 | 02:10 PM
jetjockey's Avatar
jetjockey
As long as the steel of the tank is sound the heat should have no adverse effects.
I would become very familiar with the installation by using the incorrect/old one though.
If the car is not disassembled or if you do not have power brakes, your lucky, but it is still a BEAR of a job to re-install that dude without scaring/scratching it!!
If you do have P-brakes it is even more of a BEAR.
Old May 29, 2012 | 02:13 PM
Go Vette Go
Originally Posted by Alan 71
Hi John,
Regards,
Alan
Thanks Alan!
Old May 29, 2012 | 02:18 PM
Go Vette Go
Yeah - has power brakes but I have done this before. And it is a PITA but doable. The OUT & back IN are the issues - the rest isn't bad.
Thanks for the replies. First order of business is to get the 2 port tank powder coated.
Old May 29, 2012 | 02:48 PM
...Roger...'s Avatar
...Roger...
One safety thought comes to mind and its way out in left field but I have seen some vac tanks with gasoline in them so be careful of the fumes.
Old May 29, 2012 | 02:53 PM
Go Vette Go
Great point Roger! The tank has been sitting for several years so any gas should have evaporated if there ever was any in there. I will still be very cautious when it goes into the oven.
Gotta love this forum!!!
Old May 29, 2012 | 07:11 PM
longbros's Avatar
longbros
I am about to pull the vacuum tank on my 70 with power brakes. Is there any way of getting that tank out without removing the power brake booster? My car has A/C, and I looked up under the dash and could barely see three of the nuts, could not see the fourth one. It looks like a nightmare!
To 69 Vacuum Tank Question
