Removal 68 Ignition Switch
Old Jun 2, 2012 | 06:21 PM
54greg's Avatar
54greg
Default Removal 68 Ignition Switch
Any suggestions on the most direct route?
Old Jun 2, 2012 | 08:36 PM
...Roger...'s Avatar
...Roger...
Remove the key tumbler first,then remove the outer ring,then remove switch.
Old Jun 2, 2012 | 08:47 PM
54greg's Avatar
54greg
Tumblers out rings off having trouble getting at the switch. Pull it out of the center or the left side dash?
Old Jun 2, 2012 | 08:55 PM
...Roger...
I usually just pull it back and down.
If the center cluster is out that should make it easier.
To Removal 68 Ignition Switch
