Side pipes - replacement
Old Jun 3, 2012 | 08:28 PM
Noy2014's Avatar
Noy2014
Default Side pipes - replacement
My '68 came with beautiful chrome side-pipes. Each pipe is in 4 parts.
- Pipe from the engine, the 90 degree elbow, long part of the pipe (covered by chrome heat shield, and the end chrome piece.
For some reason, the elbow piece which connects to the long side pipe, first had it's chrome finish distorted, and now it's rusting way.
What might be causing this?? And more importantly, does anyone recognize the manufacture, so that I can look into a replacement.
Old Jun 3, 2012 | 08:30 PM
Noy2014's Avatar
Noy2014
Just to show the entire side-pipes.
Old Jun 3, 2012 | 08:49 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Cannot answer your question...wanted to say great looking ride
Old Jun 4, 2012 | 03:00 AM
Scottd's Avatar
Scottd
Those are Patriot performer side exhaust pipes, sold by Summit and a few other large retailers. Summit sells each part individually, but once you see how nice and shiny the new elbow is, your going to want to replace the entire setup. They arent all tht expensive either. Make sure you measure your present set, as the kits come in different lengths and can be a bit finicky to hook up to aftermarket headers.
Old Jul 15, 2012 | 09:24 AM
Noy2014's Avatar
Noy2014
Thanks Scott, I'm almost ready to move on replacing the pieces.
One question though, the elbow on one side discolored and then rusted much fast than that other side (which is still in decent shape). Could that be a result of a bad connection to the exhaust, maybe escaping air? Or just some fluke issue with the part itself?
To Side pipes - replacement
