Instrument lights 74 C#
Old Jun 9, 2012 | 03:09 PM
brhulen's Avatar
brhulen
Default Instrument lights 74 C#
My panel or instrument lights are not working. Checked the fuse first and it's okay. Checked with trouble light and am not getting power to the fuse. So I am correct in thinking the light switch is defective?
Old Jun 9, 2012 | 07:21 PM
7T1vette's Avatar
7T1vette
Is the 'dimmer' **** on the headlight switch turned fully CCW?
Old Jun 9, 2012 | 08:19 PM
brhulen's Avatar
brhulen
Yes it is!
Old Jun 9, 2012 | 10:35 PM
7T1vette's Avatar
7T1vette
Then it won't have any output voltage to the instrument panel lights. Full "OFF" is CCW; full "ON" is CW.
Old Jun 10, 2012 | 12:18 AM
brhulen's Avatar
brhulen
Sorry about that, it doesn't work either full CCW or CW. I've already got the steering column down replacing the IS so might as well go ahead and pull the switch and test it.
Old Jun 10, 2012 | 11:03 AM
7T1vette's Avatar
7T1vette
Don't forget to change out the speakers in the dash, while you're in there.
Old Jun 10, 2012 | 11:36 AM
Peterbuilt's Avatar
Peterbuilt
Default Welcome!
Center gauge cluster and the wiper switch ground through the center terminal of the water temp gauge, check there for a good ground. The other end of that 14 gauge black ground wire is connected to the A pillar just under the drivers dash.
Make sure that both sides of each 3 fuses are good:
Tail light
Courtesy
Instrument
Jumper from courtesy light fuse to instrument light fuse.
If the dash bulbs light up the rheostat in the headlight switch is bad.
Schematic:
http://www.vetteprojects.com/bmv/mis...tte%201974.pdf
To Instrument lights 74 C#
