Glue
Old Jun 11, 2012 | 11:10 PM
corbettworks's Avatar
corbettworks
Default Glue
Preparing to repaint the doors while I have them off the car and noticed a separation along the bottom edge. Note the stainless ruler.
What's the remedy here? 2-part epoxy? Silicone? Construction glue? I'm all ears.
Old Jun 11, 2012 | 11:17 PM
Clams Canino's Avatar
Clams Canino
Get the correct BONDING ADHESIVE that they used to assemble the panels.
Slide some sandpaper around in there to clean it up - then bond and clamp overnight.
-W
Old Jun 12, 2012 | 09:49 AM
oldsarge's Avatar
oldsarge
I used 3M "Structural Adhesive", worked so far and its been about 6 years and holding.
Old Jun 12, 2012 | 10:37 AM
corbettworks
Thanks. 3M 8115 panel adhesive is what I need but don't have the pricy 3M applicator gun. Online, found Evercoat 815 (2-part), which uses a standard caulking gun, but can't find it locally.
Separation is only about 24" long. Was hoping to find a solution >$100.
Old Jun 12, 2012 | 02:59 PM
oldsarge's Avatar
oldsarge
Can't remember the number, but, they have a two part epoxy that just comes in two tubes and you mix and use as you go, no gun required.
Old Jun 12, 2012 | 03:19 PM
Mgrad92's Avatar
Mgrad92
JB weld and duct tape
Sincerely,
Bubba
To Glue
