Spring Compressor
Old Jun 13, 2012 | 10:06 PM
hicswa's Avatar
hicswa
Default Spring Compressor
What is the best type of spring compressor to get for a C3?
Thanks,
Danny
Old Jun 13, 2012 | 11:07 PM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
I assume you are talking about the front springs. When I replaced all the bushings and ball joints on my 73 resto project and started the reassembly I just put the spring in place, ran a piece of all thread through the shock mounting holes with a steel plate on each end and started tightening the nut, compressing the spring enough to mount the ball joints. Once you have mounted the spindle with the ball joints remove the all thread and install the shock. Hope this helps.
Old Jun 13, 2012 | 11:29 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
For safely compressing front coils, the tool you're looking for is one of these from K-D...
...and take care to use it correctly. You're dealing with a bunch on energy.
Old Jun 13, 2012 | 11:33 PM
spdrcr29's Avatar
spdrcr29
Hey Danny,
Below are some photos of the spring compressor I purchased. I am assuming you are looking for one for the front coil springs? Anyway, I purchased this one from Advance Auto Parts. I believe I paid about $35 for it. What I ended up doing is removed the non-threaded claws (one is threaded, the other is not). I then found a large washer to install at the top of the threaded rod. From there, I inserted the threaded rod through the top where the shock would bolt to. Prior to sliding the rod all the way through, I inserted the coil spring and then fished in the claws with the threaded part and connected to the coil spring. From there, I slowly tightened the rod to start compressing the coil. The tricky part was to get the coil somewhat compressed, but loose enough to move it over to the lower control arm pocket. Once the spring was seated in the pocket and oriented correctly, I began to jack up on the lower control arm while tightening the threaded rod from the spring compressor at the same time. It was a little tricky to do at first, but once I really figured out a good sequence of jacking the control arm and tightening the rod, it actually worked out really well. The first side probably took me about 30 minutes, but the other side went much qucker. The last photo will kind of give you an idea how the compressor was inserted and used to compress the coil spring. Maybe this was more info than you were looking for, but will possibly be helpful for others reading this post...
Old Jun 13, 2012 | 11:36 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Thats the way to do it.
DO NOT use a Impact gun to tighten the spring compressor
Old Jun 13, 2012 | 11:40 PM
TheSkunkWorks
spdrcr29's is prettier than mine, but it's a few decades newer too. Good post.
Old Jun 13, 2012 | 11:46 PM
mark6669's Avatar
mark6669
Old Jun 13, 2012 | 11:49 PM
spdrcr29's Avatar
spdrcr29
Do NOT use air...use a wrench and use your muscles!
Old Jun 14, 2012 | 12:07 AM
hicswa's Avatar
hicswa
Originally Posted by spdrcr29
Hey Danny,
Yes. I want to remove the front springs. The body is off and I am stripping the frame.
Thanks,
Danny
Old Jun 14, 2012 | 12:12 AM
spdrcr29's Avatar
spdrcr29
Removing your old springs should be a breeze using this method. Compress the spring, remove spindle from ball joints, drop down (or completely remove) lower control arm, and then slowly release the tension on the coil spring compressor. Going back together will take a little longer...
PS: For some added sense of security/safety, you can always use a ratchet strap and wrap around the control arms and slowly release as you let off the tension of the compressed coil spring.
Old Jun 14, 2012 | 03:56 AM
oldalaskaman's Avatar
oldalaskaman
http://willcoxcorvette.com/repairand...lp.php?hID=296
this doesnt require anything but removing the shock.
Old Jun 14, 2012 | 10:50 AM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
I have used coil spring compressors in the past, but for me using a piece of "all-thread" installed in place of the shock absorber is by far the easiest and safest method. I was amazed at how easy compressing the spring was just by using a normal wrench. This method does require removing the the lower "a-frame" but I feel it's worth this step.
See post #79 from my '64 thread:
http://forums.corvetteforum.com/c1-a...ressure-4.html
Old Jun 14, 2012 | 11:24 AM
mysixtynine's Avatar
mysixtynine
I hate messing with spring compressors. I haven't had one that hasn't skipped off.
This is the design I have used on the corvette several times and has not skipped off.
http://www.google.com/products/catal...d=0CKIBEPMCMAE
The following is the best design I have ever seen and works great and is safe. Works well on 55 chevys which have enormously long springs.
http://www.classicchevy.com/coil-spring-compressor.html
Use plenty of never seize on the threads and between the washers that are used as simple bearing to keep it smooth.
Old Jun 14, 2012 | 10:23 PM
oldalaskaman
http://api.viglink.com/api/click?for...13397268248555
this is the same as the wilcox tech, but when I used the wilcox version and used a leftover spring bolt from my c4 and a left over piece of 3/8" steel, it didnt cost me anything and still got the job done ...safely.
Old Jun 14, 2012 | 10:27 PM
glen242's Avatar
glen242
I guess I am an accident waiting to happen. I use the same method as I did 50-55 years ago.
I raise the car up to a good height, remove the shock absorber, put a hydraulic floor jack under the lower control arm, unbolt the spindle from the lower ball joint, and slowly lower the jack. If the car was jacked up far enough, initially, the lower control arm, along with the coil spring, will swing down so it can be removed. Installation is the reverse of removal. You can chain the coils together, for safety, before you lower the jack.
I survived, these many years, using this method, in a commercial garage, working on a dirt track late model modified, and at home.
Old Jun 15, 2012 | 04:42 PM
Mashman's Avatar
Mashman
That's exactly how I removed mine. But when I went to reinstall the springs, I could not get it to work, I could not get the spring to seat in the proper location in the upper pocket.
That's when I went out and got the same compressor as spdrcr29. I ran the compressor bolt up thru the upper hole for the shock, and compressed the spring up into the upper pocket. This easily allowed me to get the spring seated correctly in the pocket. With the spring compressed into the upper pocket, the lower arm easily swung up with the spindle on it, and allowed me to connect the upper ball joint.
After spending MANY hours trying to get the first side on, after coming up with this solution, the second spring was in in 10 minutes.
To Spring Compressor
