Stencils
Old Jun 18, 2012 | 11:29 PM
LBI 73's Avatar
LBI 73
Default Stencils
I am in the process of restoring my 73 and I can't seem to find the exact placement of frame, gas tank, and drive shaft stencil. I also need to find the color ink those stencils used for that year. From what I researched I believe the frame and gas tank were white and the drive shaft was yellow.
Kevin
Old Jun 19, 2012 | 06:01 AM
hunt4cleanair's Avatar
hunt4cleanair
Kevin
Lyle chamberlain would know for sure...look him up on the forum here. I've researched late C3s and by then the frame stencil color was yellow. I have a few pics of early and they were white.
But you must also consider the letter size because it varied over the years from 1/2 inch to 1 inch.
Old Jun 19, 2012 | 07:11 PM
boat196's Avatar
boat196
Have you looked at the Chassis restoration kit by Quanta
Paint
www.gastanks.com/PAINT/departme...
I used the kit for 1970. It had everything that your asking
for.
Bob
Old Jun 19, 2012 | 11:16 PM
mark6669's Avatar
mark6669
Here are the stencil locations for my late 72 coupe still had orig tank no sign of any stencil on it.
Mark
Old Jun 19, 2012 | 11:49 PM
LBI 73's Avatar
LBI 73
mark6669
First of you did a beautiful job on your 72 and the stencil locations helped, but what do the markings near the body mounts mean? Number of shims? And what do the yellow and blue markings on the rear mean? Sorry for all the questions but I can't buy a chassis detail kit for a 73 so I am trying to make mine as complete as possible. Any more pictures would be great.
Kevin
Old Jun 20, 2012 | 08:26 AM
mark6669's Avatar
mark6669
Originally Posted by LBI 73
mark6669
Kevin
Kevin
The numbers are for shims the diff markings are quality control at the axle plant & balance mark for drive shaft I dont have digital pictures of disassembly but I will see what else I can find.
Mark
Old Jun 20, 2012 | 11:51 AM
70BBvert's Avatar
70BBvert
I know you can get the stencil for the frame from Doc Rebuild with your date code. I believe he can make the drive shaft stencil as well.
Jim
Old Jun 21, 2012 | 06:05 AM
hunt4cleanair
mark6669
Kevin
Kevin
You could get away with a 72 stencil kit...not much changed but you would need the trim tag date code and a frame number to get a stencil made that is consistent with a 73 built car. I'm in process of doing that for my 78. I don't have my 73 NCRS guide but I think it might list the frame part number for automatic and manual transmission. Start there. Its the three-digit suffix that is tough to replicate.
To Stencils
By Michael S. Palmer | 2026-06-03 09:39:05
