dynamat....
Old Jun 21, 2012 | 08:16 PM
jman1's Avatar
jman1
Default dynamat....
hushmat... dynamat.... it looks like ice and water shield.. same type of stuff?
Old Jun 21, 2012 | 08:47 PM
cb.bums's Avatar
cb.bums
remember, all these are meant to dampen vibration in metal panels. drumming is common in metal, a bunch different in glass. a 76 and up metal floor will have an effect, earlier, the foil side will reflect heat but drumming i don't think is an issue. use foil to reflect heat back down through the floor. bout as good as you can do.
Old Jun 21, 2012 | 09:29 PM
markids77's Avatar
markids77
There's sound deadening material, and reflective/insulative material. Attenuating sound requires adding mass, and changing the harmonics of the substrate. I believe the Grace ice and water shield I have left over from a recent roofing repair will do the trick there. I added a layer of Reflectix; a reflective/insulating material over the Grace product. Both of the layers together are only approximately 1/4 inch thick and don't seem to interfere with carpet installation, although I ran out of Reflectix before I finished the front floorboards. Rear carpets and storage box assembly went in perfect though. I expect the result will rival if not surpass the vastly more expensive "commercial" products.
Old Jun 22, 2012 | 02:20 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i used relectix exclusively on the re-build of my 78 and it has been of tremendous help in reducing cabin heat levels. i would also suggest if possible that you do the best you can to use it to line the doors also as a great amount of heat has always "rolled" up the body sides on corvettes of almost every generation.
Old Jun 22, 2012 | 05:41 PM
U17's Avatar
U17
I use my $1 set of ear plugs.... Works everytime...
Old Jun 22, 2012 | 05:56 PM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
I dont worry about the heat...just drive around bear chested in a pair of old tighty whiteys
Old Jun 22, 2012 | 06:51 PM
MikeKey's Avatar
MikeKey
Not even close.
Those are sound deadeners/vibration dampening material. A matter of fact, my dynamat box says not to get the stuff overly wet.
Old Jun 22, 2012 | 07:00 PM
mds3013's Avatar
mds3013
Only needed if you like to BASS a certain type of music on your highly amped and sub woofered stereo. Not needed on my car with '70's and '80's rock. Modern music of a type I do not understand has a VERY hard bass line that is designed to rattle the windows of the car three lanes over. These products keep your car from vibrating itself into little pieces. mike...
Old Jun 22, 2012 | 08:23 PM
MikeKey's Avatar
MikeKey
Um or if you want a quiter cabin. I did my whole car and so have others to quite the car. I don't even have speakers in my car.
Old Jun 22, 2012 | 08:44 PM
1976 corvette's Avatar
1976 corvette
Here is what I did but I will most likely use the stuff Eastwood sells whe I do the 68.
http://www.mycorvetterestoration.com...20proofing.php
Old Jun 22, 2012 | 09:07 PM
mds3013's Avatar
mds3013
Um or if you need a quiter cabin with no stereo. What do you listen to? Isolation tank? mike...
Old Jun 22, 2012 | 10:44 PM
MikeKey's Avatar
MikeKey
Quality comments, why to go superstar.
Old Jun 22, 2012 | 10:59 PM
mds3013's Avatar
mds3013
No disrespect intended. Just asking a simple question. Advice, get a sense of humor. We all can be off our game from time to time. Put me on ignore if you wish. mike...
To dynamat....
