fuel line question
Old Jun 24, 2012 | 09:53 PM
vish2000's Avatar
vish2000
Default fuel line question
Is there any rubber hose near gas tank?Installing a throttle body with electric fuel pump and concerned about line pressure
Old Jun 24, 2012 | 09:56 PM
KenSny's Avatar
KenSny
Do not use a rubber fuel line between electric fuel pump and the carb or injection system.
Rubber ok between tank and external pump.
Old Jun 25, 2012 | 03:19 PM
scottw's Avatar
scottw
Yes there is.
KenSny is right. Only use the rubber hose where there is no pressure. You can bend a metal line up pretty easy for use anywhere there is pressure after the fuel pump.
Old Jun 26, 2012 | 08:29 PM
texaswilkins's Avatar
texaswilkins
Here's what it looks like on a 72. All of these lines you can see are low pressure. Two on the left side, one on top and two on the right side. In the lower right corner there is a stainless tube along the frame that has a 6 inch rubber hose going to the tank. With the in tank pump, that's the one that will have pressure.
Bill
To fuel line question
