Removing front bumper
Old Jun 29, 2012 | 12:58 AM
Dirk76's Avatar
Dirk76
Default Removing front bumper
Just started the first thing in my frame off. Going well ,until....
Those bloody 14 little nuts that hold the front bumper on. I have remove the middle top 3, and lower one on the side of each side.
But how do you get at the far left and right one and the top side ones.
Was using a ratch 3/8 for the others, but i cannot get into there.
Old Jun 29, 2012 | 07:12 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Are you planning on reusing this bumper? Most original rubber bumpers are near junk after this many years and I would think you would want a brand new bumper when all is said and done.
Grab the utility knife and cut it off.
Old Jun 29, 2012 | 07:27 AM
Dirk76's Avatar
Dirk76
done!
Old Jun 29, 2012 | 07:56 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Did you cut it off or figure it out?
Old Jun 29, 2012 | 08:01 AM
Dirk76's Avatar
Dirk76
Cut as replacing it anyway with a newer one.
Old Jun 29, 2012 | 11:36 AM
blckslvr79's Avatar
blckslvr79
That worked for me too.
Old Jun 29, 2012 | 11:55 AM
~Stingray's Avatar
~Stingray
Just hearing this is making me cringe.
Old Jun 29, 2012 | 12:33 PM
blckslvr79's Avatar
blckslvr79
Getting to the little bolts at the end of the bumper is nearly impossible and when you do, and they are rusted, you may as well give up. I used a cut off wheel and cut the old bumper cover off about an inch from the body seam all the way around. Made the process of removing the tiny little bolts much easier. Some of them also had to be cut off.
The rear bumper cover, on the other hand, was a piece of cake.
Old Jun 29, 2012 | 07:26 PM
tyrant's Avatar
tyrant
Cut mine off as well, wait to the thrill of installing the new one!
To Removing front bumper
