main ground
Old Jun 30, 2012 | 08:32 PM
marines's Avatar
marines
Default main ground
Trying to head off a problem at the pass. Where is the main ground for the electrical system on the frame? I know that it is there but just do not know exactly where. I have been having a little problem with failure to start (not even the rudimentary crank) and I think it may be a loose ground but do not know where to start. I appreciate any help, as usual. Believe it or not I am learning and like what I am doing....so far at least.
Mike in Alabama (110 today!)
Old Jun 30, 2012 | 08:40 PM
Duke94's Avatar
Duke94
Battery to frame is right under the batt compartment. Frame to engine front motor mount bolt.
Gary
Old Jun 30, 2012 | 09:34 PM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
Had the same problem on my 81. Cleaned the battery ground and problem solved. On these cars if something doesn't work check the ground first
To main ground
