Frame Ground
Thanks for letting me know where the battery ground is located on my 74 C 3. I think I have isolated the problem to the battery. Ran ok, disconnected the negative terminal and she still ran. It used to be that if she continued to run the alternator was ok; but if she stalled, then teh alternator was defective. This still true? Also, the replacement batteries all show side mount cable mounts whereas mine (through the PO) has top posts. Any difference? Thanks guys. I appreciate your advice. Some good information from the forum.Semper Fi !!
If the alternator is working properly you should see ~14 volts at the battery with the engine running.
Top posts are no different from a battery function perspective. The side posts are safer - harder to drop a wrench or something across the terminals.
Rick B.
Rick B.
Also a $3 test light will be good investment,I use one of these for 95% of my electrical troubleshooting.
Thanks, Rick I appreciate your response and I think I am going to have to get one. Have a great and safe 4th of July
